To big to post
RE: To big to post
Do all of the modem owning users a favour and use an image editing program to reduce them to around 70 to 100K file size. Actually RCU will reduce them anyway as long as they are within the guidelines.
RE: To big to post
Walther,
I like to use .jpg files of ~800 pixels wide and ~72-100 dpi. These become smaller files that still show good resolution on a screen and are of a width that you do not have to scroll to view.
Another trick is to crop the picture, eliminating stuff you don't need to show.
Good luck with your pics.
George
Edit: Forgot to mention, make a copy of the pic before you start so you can make alterations on the copy and still have the original.
George
RE: To big to post
I've been using Picasa (it's free; http://picasa.google.com/) and it works great. One can zoom and adjust horizon etc without altering the original file. Batch conversion of selected files and exports into new files of desired size and resolution, highly recommended!
RE: To big to post
I'm not on the correct computer right now, so I can't double check, but the original file should be intact and can be opened in another program to reveal the original image. Picasa registers the changes done to a picture, rather than changing the file, and shows the picture within picasa the way you have choosen too, but this should be done without altering the original picture...
RE: To big to post
I found a passing in the manual:
Note: Picasa never overwrites your original file on disk; any edits you make to a photo are only saved inside Picasa until you decide to either export or click the "Save Changes" button in the album header.
RE: To big to post
The you had probably saved the changes to the files, which is not nessecary to do, Picasa should remember how you want to see your pictures within picasa. When exporting these then it is the view within Picasa that is exported.
RE: To big to post
ORIGINAL: Walther
Mr Cox:
I just posted some pictures in Some like them flat, and when I tried to open my original it had been altered.
Mr Cox:
Or if you're reffering to how RCU alters the picture you just need to live with that. When you post here the RCU software automatically reduces larger file sizes to a smaller size to avoid using excess room but mostly to avoid the format being too large for a lot of folks monitors. It also keeps the site friendly for those still using modems.
RE: To big to post
ORIGINAL: Walther
Mr Cox:
Mr Cox:
Get into the habit of doing the copy or save as BEFORE making any alterations. Get out of the pic you are in withoud doing another save. Now open the saved version and do your alterations. MAKE SURE you do a name change for the save-as or you will just be altering the original.
I use a "limited edition" version of Photoshop which came with my computer. It works fine for me.
Good luck.
George
RE: To big to post
Yes, for Photoshop it is best to just make a copy straight away and to play with that one.
What I've been trying to explain is that Picasa is meant to work in a different way. It can be used to only register how you want to see different images without actually making any changes to the files themselves. I realies now from this thread that the best thing is to put all original files onto a CD straight away, and to store that in a safe place. Well away from any nitro and lipos etc
