Cox .049 stainless reeds
OH
Is it possible to order, or is anyone making stainless steel replacement reeds for the cox Sure Start engines. If not does anyone know where you can buy mylar reeds or what ever replacement reeds. I know they can be made, but I'm looking for a place where the work has been finished
Thanks in advance Bill
MO
RE: Cox .049 stainless reeds
I picked up a few Mylar reads reasonable on the fleab. I don't really know which on is better mylar or stainless i wonder if stainless is hard on the plastic housing?
OH
Thanks for the information I will ckeck out Davis Diesel for the teflon reeds, If all else fails I will find out about where to get teflon or what ever for making my own.
THANKS Bill
THANKS Bill
ORIGINAL: digital_trucker
Not all that hard to cut some out of a floppy disk (the actual disk that is, not the casing).
Perhaps they don't even use iron oxide any more. I remember it from my "tape" days.
I have heard about but never used floppy's for reeds.
George
ORIGINAL: gcb
Have you had problems with the iron oxide recording media coming off the plastic, or do you remove it first?
The most common coating on the typical 3.5" high density diskette is a cobalt-ferric compound. The earlier 8" and low density 5.25" floppies were mostly iron ferrites.
The coating is so thin and uniform that I never thought about removing it. I suppose that over the long haul, if enough sloughed off, it could contribute to some wear, but I would expect it to be minimal. It can be removed with pure acetone without harming the mylar, but I'm not sure its worth the effort. The mylar substrate is incredibly tough and I've never been able to tear it with my fingers alone -- of course, YMMV.
