"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Servo size
Old 03-25-2008, 02:00 PM
Walther
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo size
What size "torque" servos would you need for ailerons on a 20 oz plane using one per aileron?
Walther is offline
Old 03-25-2008, 03:29 PM
Remby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Servo size
I use the Futaba 3112s for this type of setup. How much power you really need has many factors, the weight of the plane, size, how free the surfaces are,etc. The ones I mentioned have good torque, and are light, quite small, and have been trouble free.
A down side is they are not setup for gas, intended for electric powered aircraft, they have no grommets. However, adding them is easy if you give it some thought, all of mine have grommets in different ways.
Torque of 20oz should be more than enough for any 1/2a alerons setup you can think of.
Remby is offline
Old 03-25-2008, 05:13 PM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Remby
3112? Or did you mean 3114?
Andrew is offline
Old 03-26-2008, 01:52 AM
Remby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Andrew;
You are correct, I meant to state 3114s, not 3112s.
Remby is offline
Old 03-27-2008, 10:28 AM
Walther
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used HS55 in my last plane but I think I will go with the Futaba 3114 this time. I have never built a RC 1/2A plane before, it has all been a lot bigger stuff.
Walther is offline
Old 03-27-2008, 10:49 AM
chevy43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use HS55's throughout on my 33 oz .19 powered Little Extrea 36" span with no problems at all. They won't put up with being bumped while moving the plane around though.
chevy43 is offline
Old 03-27-2008, 02:06 PM
Remby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Walther;
Good to see you'ins taking the 1/2a plunge! The futaba's are a good little servo. I think anything around a .15 would be fine with them, provided a bit of vibration protection for them, all should be well. I prefer a "Y" wire to two servos setup, it makes for a solid responce from the model.
Never had any of the 55's myself, they are mentioned in the 1/2a posts quite often.
Keep us posted on your progress.
Remby is offline
Old 03-27-2008, 02:25 PM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is also the HS45, it has the same weight as the HS55 (8grams), it is a little bit smaller (narrower) but more importantly the gears are carbonite and they are "thicker" (i.e. larger overlapp between gears) than the ones in the HS55.
It looks very promissing since it is the gear stripping on the HS 55 which is trobblesome. I only have one HS45 so far and I will use it for throttle first, before I put it onto something more important...
Mr Cox is offline
Old 03-27-2008, 06:30 PM
cyclops2
cyclops2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HS-55's ARE durable & strong. I have never, many years EVER lost a 55.
4 of them control all 4 tail surfaces of the 80" A-10 just fine.
cyclops2 is offline
Old 03-27-2008, 10:20 PM
air-madness
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hear folks speak highly of the HS55s, but, I have had very bad luck with them - I hate them actually. I do like the 45s, futaba 3114s, and HS85s - I really like the 85s as they have never once given me problems and there is a metal gear option and the carbonite gear set avalible. I even use the 85s in 1/2a planes with no problems. To each his own, I suppose.
air-madness is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
