Will it fly?
WA
Will it fly?
This is my first attempt at a plane this small. Any advice from you experienced 1/2 A guys is appreciated. I have been flying .40 to 1.50 sized planes for over a decade and thought I'd give this miniature part of the hobby a try! Hey, if I like it, I may go smaller. Here are the specs:
OS 10 LA
26" top wing span
307 sq. in. wing area
27 oz. AUW
So, based on other planes in this size/ weight range, what flight characteristics can I expect?
BTW, it is a "Twig" stick biplane produced by Celerity Aerospace Designs in the mid 90's. I modified a bit to include cowl, 4 ailerons, tail wheel, and counterbalanced tail surfaces.
OS 10 LA
26" top wing span
27 oz. AUW
WA
RE: Will it fly?
Hitec HS-81's on all channels. Ni-Mh 700 mAh batt. 17g JR reciever. Yeah I was thinking about keeping the low rates REALLY low because of the 4x ailerons and counterbalanced tail. But the high rates are gonna be wild for sure. I'll be sure it's got some altitude for the first flip of the high rate switch. Will the 2oz tank yield a reasonable flight time with the OS 10. I can squeeze a 4oz in there if I find the run times a bit short I suppose.
Thanks much
Thanks much
WA
RE: Will it fly?
That 2oz should get you decent flight time with that .10. Have you tried a WOT test of it to see how long it'd take to drain the tank?
A few things I noted when I maidened my smaller bipe when compared to my larger .40 size planes is that it got knocked around more by gusts and that four ailerons on a bipe can roll it pretty quickly. Plane was also much more sensitive to small bumps in our runway during take-off and landing.
Good luck on the maiden!
somegeek
somegeek
RE: Will it fly?
Great looking model! Sounds like you're all set to have some real fun. Have you checked the wing allignments in all directions real good and balanced the plane in all axis?
A plane like this needs to be dead on. I'll bet you find that 1/16" of aileron is enough for mild flying, 1/8" enough for a stiff drink after you land it.
WA
RE: Will it fly?
I spent a good amount of time making sure the wings are nice and square to the fuse and each other. Equal distances form each wingtip to the stab TE. Today is balance day and final inspection. I've got unlimited space to mount the battery anywhere between the tank compt. and back of the fuse. It's snowing here so no temptation to finish quick and go maiden today. Thanks for the input guys.
WA
RE: Will it fly?
OK, I'll do my ceremonial anti-rain, no-wind, perfect maiden flight weather dance. You'll know when the twig goes up cause the clouds will part around Tacoma.
WA
RE: Will it fly?
Funny you should mention the twist. The wings were very straight right off the building board. But after covering, one side of the bottom wing had a huge (aprox. +5 deg. at the tip) twist. A little work with the iron and an assistant (my loving understanding wonderful wife) and the twist was gone. Had I overlooked this, I speculate the results could very well have been disasterous.
VA
RE: Will it fly?
One word of caution: after your maiden small plane flight you will be dissapointed by the ho hum run of the mill birds you were used to flying. Prepare to sell all your .40 and up sized planes to the unimaginative mob that inhabits your favorite flying field. You are one of us now. You have been upgraded, you are now human 2.0
WA
RE: Will it fly?
OK, it looks good in the air, That's about all it did good in the air today. Almost ate the dirt a couple times after takeoff. Very hard to trim to level flight. With only 1/4" of elevator throw, pitch corrections were extremely exaggerated. The old favorite tell-all of a tail heavy airplane....squirly!!! Somehow I managed to land it without a scratch after a 5 min. "pucker factor" flight. The pictures of the maiden are of poor quality, and the video of the maiden contains some poor language. Sorry folks, I have no useful information or cool video about the maiden flight. I am going to move the CG forward about 3/4" from where it is now. The weather is supposed to be nice here all week so hopefully I get another chance to see what this plane can really do. I will try to get some good video and pictures then.
WA
RE: Will it fly?
Oh yeah, even though the plane flew like crap, I am still super excited about this 1/2 a thing. When this plane gets back in the air and flies like something other than a sock full of D-cell batteries, I will let you all know if I am ready to sell off all of my big gas guzzlers in favor of a few planes I can put in the trunk of my mazda. Later
RE: Will it fly?
ORIGINAL: silkyt
