Tired of JUNK
#51
RE: Tired of JUNK
" Doesn't look like making the airbleed adjustable on the Mp Jet is going to work, not enough meat on the carb housing anywhere to put a screw. Their 2-needle carb must've used a different casting."
DT.
the MP Jets carbs are the same, if you look at the throttle arm side of the barrel you will see a threaded hole this is were the low end needle screws in - the hole just isnt bored right through. All you need is the low end needle and drill the hole.
Stewart
DT.
Stewart
#53
RE: Tired of JUNK
Unfortunately my only MP Jet with carb is a single needle type too, am trying to find a twin needle carb for my BB diesel.
Stewart
Stewart
#54
My Feedback: (12)
MT
RE: Tired of JUNK
ORIGINAL: digital_trucker
Any info on what the low end needle looks like and the size of the hole? I don't have a 2-needle carb to compare.
The needle is approx. .039" in dia.. (A # 60 drill bit fits snugly, but not interference.) The threaded end is approx. .116" dia. across the threads. (3 mm) My thread gauge & I are about 1500 miles apart, & my eyes are bad enough that I can't count threads, but the Hi speed needle thread pitch looks to be the same. The overall length is approx. .587". Of that, approx. .195" is threaded. If you machine a needle, you'll still have to put a plug into the fixed bleed hole. The existing cavity in the crankcase is rather large, approx. .300" x .209". Might consider filling it with Devcon F, & drilling it out for some existing usable carb??? ........ George K
#55
RE: Tired of JUNK
OK, you guys are confusing me on this MP-Jets 2-needle carb thread.
I have both the glo and diesel RC versions and they have a little screw type needle on the throttle arm side.
If I pull the primary needle and the screw needle I can see daylight through the spray bar so mine do not need drilling.
Here is a picture of the screwhead needle side of the carb.
#56
RE: Tired of JUNK
Dan, Both yours look to be BB type engines which are supplied with the twin needle carbs, wereas the plain bearinged engines (silver/plain head) were supplied with the single needle carbs. Oh just to confuse things there was a late production run of plain bearinged diesels with the black anodised head and prop driver- I have 1 with a C/L venturie.
Stewart
Stewart
#57
RE: Tired of JUNK
Agreed Dan,
I was confused also and looked at three of mine this morning (diesel BB,PB and Glow) They all have the same carb as shown in Dan's photo. The paperwork reference a SN-1 carb. I have a couple more and even a carb or two bought independatly but they are down at the Hanger and I woun't get there till this weekend.
Any way, I've not run my glow but the diesels idle very well with this carb.
#58
RE: Tired of JUNK
ORIGINAL: SGC
Stewart
Stewart
#59
RE: Tired of JUNK
OK, I get it. The PB engines have the simple carb. Or should I say "Some of the PB engines)
It's all to much for my pretty little head.
I'm going back to my old faithful McCoy .09 diesels.
#60
RE: Tired of JUNK
So how does the inside end of that idle needle work? I take it there is no airbleed hole in the barrel then? It actually adjusts the fuel end of the idle mixture?
#61
My Feedback: (12)
MT
RE: Tired of JUNK
#63
RE: Tired of JUNK
Got my PAW .049 today from Mr. Clutton. What a little pretty! It was nice to smell it too (he pre-runs 'em for all of us diesel dummies). Brings back the memories of my PAW .19 I had back in the '80s hauling around a Kadet Jr. (good vertical it had).
I hope the fuel comes soon, I can't wait to run it
#65
RE: Tired of JUNK
DT, I think you might be the first member of this forum who will be able to give us regular 1/2A diesel flight reports. There have been other reports before [with conversions], but they have usually ended with photos of broken parts. Hopefully you end up with a 1/2A engine that does it all.
#66
RE: Tired of JUNK
It's been so many years since I've run a diesel (and even then not much) I wouldn't even THINK of mixing my own. If the PAW .049 performs anything like the .19 I useta had, it's gonna be a winner.
Luckily I kinda like the smell of kerosene (I'm a trucker after all) and the smell of ether (I'm crazy too).
#67
WI
RE: Tired of JUNK
Well I suppose I could understand that. I just could never see spending 10 bucks a pint ( or whatever it is now) for what costs me 2 to mix quick. Ive never run any ignition improvers, never really found a need to, and it lessens the corrosion risk quite a bit. Ive never understood why some of the diesel "conversion" places treat it like such a mystery. Ive run the heck out of my 1/2A diesel engines on a 60 year old formula. Oh well, I suppose they have to make their money too. Well if your ever driving through WI and want some blended up let me know!
#70
WI
RE: Tired of JUNK
Nope that you cant go wrong with. Eric has done much to bring "real" diesel engines to the US for a second go around I think. The nice thing is that he sells the tried and true technology fuels and engines that have been around for just about ever. My PAW .049 has to be about the most reliable 1/2A engine out there, and spinning a 7-3 APC at 12k isnt bad either! I lost count of how much fuel ive run through mine, in 3 different airplanes, but it amazing how that ol' iron piston and steel cylinder keep cranking away hour after hour. Its almost as convienient as.....an electic! Fuel it up, give it a little prime, 3 or 4 flips, adjust the compression and mixture a tad, and chuck it in the air. Pint of fuel lasts a whole weekend plus of flying....ahh what fun.
#71
NC
RE: Tired of JUNK
CP,
The only diesel project of mine that I reported on in this forum was the PAW .049 powered all-FFF model that I flew a couple of times - once at one of Rog's events. It was a converted 3-D electric design that really didn't lend itself to Internal Combustion power but I was curious as to how the foam would hold up under the ether in the fuel. So I put it in storage for a year and there were only a small place or two where I hadn't sealed the raw cut edge of the foam but other than that it was all OK.
My original intention was to then fly it with a glow engine but like I said it really wasn't designed for IC power. Right now my favorite diesel engine (PAW 033) does not have a home but I haved it and two other small PAWs mounted on a sophisticated test fixture (board) that I take out and run the liitle jewels once in a while (love that smell). FWIW I'm hoping to hear that I'll be allowed to buy a Mills (sorta) replica from Down Under "any day now". Watch for it in a Tomboy coming to this forum soon.
#72
RE: Tired of JUNK
That would be a cool project to follow, Sir Stenchalot of You-reeka!
Much better than looking at another "1/2A diesel bolted to a picnic table" type thread.
99.9% of all the diesel run time [over about a 10 year span] I ever saw at our local club field was little diesels bolted to a picnic table. I started to think that they all needed 20 hours of bench time to be ready.
#73
RE: Tired of JUNK
CP, Here are a couple of 1/2a or less Diesels not hauling around a picnic table
[link=http://www.rcuniverse.com/forum/m_7283054/tm.htm]Jack Rabbit MPJett 1cc (.061" )[/link]
[link=http://www.rcuniverse.com/forum/m_5829626/tm.htm]1938 Mercury - .33cc (.020" ) Peter Burford[/link]
[link=http://www.rcuniverse.com/forum/m_5734554/tm.htm]1939 Lancer .25cc (.015" ) Schlosser[/link]
#74
WI
RE: Tired of JUNK
ORIGINAL: makoman1860
Ok, I am from down in milwalkee, and spend a lot of time up there. What is the mix Keosene, castor and Either I'd guess, where do you get the either. Cans of starting fluid?
#75
RE: Tired of JUNK
Anybody try one of these? It's a NorVel and yes it will turn a prop. Just needs a little off the top so to speak. http://cgi.ebay.com/NORVEL-061-Sport...QQcmdZViewItem
