Tired of JUNK
#76
WI
RE: Tired of JUNK
Uliner,
Unless an engine builder wants otherwise, I have found the old "equal parts" diesel mix to work very well, and be very safe. Simply put its equal parts kerosene, ether, and oil ( castor or aeroshell 120 ). Some of the fixed compression engines have their own special blends needed. Ether can be bought from a few places, but it helps if you have an "in" with a petrol/chemical company. The starting fluid I have found to work very well, with the deere and solder seal "instant" having the highest ether content and working just fine in even sub .5cc engines. I get pint size screw top cans from MSC to keep the fuels in, only a buck or 2 a can. There is a nice feeling of being able to go to tractor supply and get dang near all of your fuel needs.
#78
RE: Tired of JUNK
Good recovery, CP.
I enjoy your quips, was tempted to post a comeback, but thought that I would bide my time and let someone else in first.
I didn't need to wait long!
Maybe we should have an alias to post replies?
Peter
Peter
#79
RE: Tired of JUNK
I love the scaled down Old Timers with RC and tiny diesels. Keep the pictures coming.
Hey CP, if people think Led Zeppelin is old, what does that mean for me who still appreciates Glen Miller, Benny Goodman, Harry James and others from the swing era who made such fabulous music without all the electronics and gadgets available today?
#82
RE: Tired of JUNK
Dan, don't forget Tommy Dorsey! Did you know that ex fed chairman Alan Greenspan was a swing band musician?
It was shocking to hear a young punk at work tell me that Led Zep was old fogie music, and this happened maybe 10 years ago!
Back to the topic.......if I let a small detail like working with JUNK get me down, I would never have stuck with 1/2A in any shape or form. It's just too easy to get a Webra .50 or Rossi .45..you know, the type of engine that starts if you just flick the spinner backwards. Working with standard sized RC gear is also such a slam dunk, if installed with any care it lasts for years.
In spite of putting up with the shortcomings of 1/2A junk, success seems more rewarding. With .40 sized stuff, success is taken more for granted.
#83
My Feedback: (14)
RE: Tired of JUNK
My Norvel .061 and .074 start with two or three flips on 5% nitro after a prime. The trick getting any of these little engines started is the correct prime, imho. The power isn't great on 5% but it's all I fly in my other planes. Everyone in my area has switched to electric on small aircraft. It's still fun to bring a glow plane out, start the engine and have it run well. For me it's the same feeling you get from building your own plane or designing a muffler or smoke system and have it perform well.
#84
RE: Tired of JUNK
ORIGINAL: rainedave
Funny, but my tanked Reedies are my best running Coxes. The only thing special I do is install Nystrom's tubing inside. Go figure.
I have an AME that will sometimes run a WOT, but dies every time I throttle down. That's one I've given up on.
David
David
Once you pop in that five port cylinder, you'll find that you've converted your AME to a Big Mig which had the reputation of idling and throttling much better. From there, do this, from this thread. http://www.rcuniverse.com/forum/m_7602431/tm.htm
A Norvel, Revlite .061 with a bolt on muffler (like the .074) and a means to adjust the mixture at idle would be the perfect, 1/2A RC engine. Maybe CS would buy the tooling and make the necessary changes.
#85
RE: Tired of JUNK
ORIGINAL: makoman1860
Nope that you cant go wrong with. Eric has done much to bring "real" diesel engines to the US for a second go around I think. The nice thing is that he sells the tried and true technology fuels and engines that have been around for just about ever. My PAW .049 has to be about the most reliable 1/2A engine out there, and spinning a 7-3 APC at 12k isn't bad either! I lost count of how much fuel Ive run through mine, in 3 different airplanes, but it amazing how that ol' iron piston and steel cylinder keep cranking away hour after hour. Its almost as convenient as.....an eclectic! Fuel it up, give it a little prime, 3 or 4 flips, adjust the compression and mixture a tad, and chuck it in the air. Pint of fuel lasts a whole weekend plus of flying....ahh what fun.
And I agree, steel and iron do make a diesel last a long, long time. AND, the PAW, despite no muffler, sounds a lot better. Must be the circumferential porting.
#86
RE: Tired of JUNK
Oh god no, don't let CS at them until they can demonstrate they can build what they already have satisfactorily. The last thing we need is yet another worthless blob of low-grade aluminum.
#88
My Feedback: (14)
RE: Tired of JUNK
Andy,
I bought a spare piston/cylinder set from them a few years ago. Still no parts listed on website. Need to call Lite Machines for parts and prices? I see they are developing and or producing dual rotor UAV products for the military. I wonder if they are in the design phase or if they have a working model of the finished product.
#89
RE: Tired of JUNK
Yes, I've always called them. In retrospect, they may not have any .06 units left. Last I did business with them, I bought several of their .07 heli engines. That was for the piston and cylinders primarily till I saw that the case in these are brass bushed at both ends. Superior to the original Norvels in my opinion. So I converted one of these to a standard carb along with adapting a proper muffler to it. There were some idling issues but recent experience has shown that this might be helped by using the OS P3, ultra-hot plug.
They may still have the .06 version,, worth a try.
But as Jeffie posted, http://cgi.ebay.com/NORVEL-061-Sport...QQcmdZViewItem that looks a lot like the .06 heli engine targeted to be used in cars. The price there, is equivalent to the price of just a piston and cylinder. Neat.
#90
RE: Tired of JUNK
Just for the fun of it, I contacted Horizon Hobby (the folks who developed the Evolution engines with Sanye), asking about the possibility of a 1/2A Evolution engine. Might be worth a try!
