Minwax Polyurethane ? fuel proof
OH
Is Minwax Polyurethane Clear Gloss? I remember reading some place that it was. I'm not talking about the water base stuff
RE: Minwax Polyurethane ? fuel proof
NO NO NO NO NO NO.....the only truly fuel proof finishes are those that require you to mix Part A with Part B. Even the epoxy paints will get dulled from exposure. The guys who claim fuel proofness up to a certain % of certain finishes don't tell you how fastidious they are about cleaning their planes.
gabe200 posted that MinWax Poly is fuel proof.
Can I trouble your for the UPC code or the part number? The local stores seem to have many flavours of MinWax Polyurethane and buying 2 or 3 versions to test could be bypassed if you can tell us the part number or UPC Code.
Jim H
Jim H
Nelson hobbies makes a beautiful line of fuel-proof water-based polyurethanes. There's an additive they sell that you add to it to paint ove open framework (or for higher than 10% fuel). It goes on wonderfully, and I can vouch for the LiteFab covering they sell too. It goes on like nobody's business...handle compound curves like a dream. It's basically natural Solartex, I think.
OH
Thanks Gabe,
The stuff I am using is Minwax Fast Drying Polyurethane Clear Gloss. The UPS code is 27426 23000 but it is an 8oz. can. The bar code is probable different depending upon what size you get. I am goint to take your bar code with me and see if it is the same thing but a different size can.
Thanks Bill
Thanks Bill
OH
ORIGINAL: gabe200
heres the the upc code 2742633050
ORIGINAL: combatpigg
I'd have to see a polyurethane finish endure a few flight and cleanup cycles of a 1/2A on 35%, before I would feel comfortable thinking it is really fuel-proof, and even then I likely wouldn't bother with it, dunno. Dope, films, and epoxy work for me, and 1/2A's use so little.
OH
My problem is not with the amount used,but I use some foam parts on some of my planes and most or the dopes and paints will eat foam. Latex being water base works on foam, but it is dull and some latex paint is not fuel proof for hi nitro use.
ORIGINAL: propjobbill
MJD
My Feedback: (8)
Yes, polyeurothane is fuel proof, here's my proof, my field box, cleared about 7 years ago and I've managed to pour 1/2A fuel in all the compartments due to my lazyness on putting caps back on the bottles, sig, byron and power master up to 35% fuel has sat in the bins and drawers for up to a week before cleaning them out. So go ahead, but the lighter fuel-proofer is sigs nitrate dopes, they dry very light and soak into the wood better than poly. The poly I use is minwax helmsman spar varnish, works very well.
Just my .02
Just my .02
ORIGINAL: planebuilder66
Just my .02
Just my .02
Is that the stuff they call polyurethane varnish, or just spar varnish - I assume the former, but thought I'd check. They are two different animals or so I'm told. I was advised not to use polyU varnish on my full scale prop, but maybe that was because it already had several coats of regular varnish, dunno.
MJD
My Feedback: (8)
You know, your right, butyrate dope is 100% fuel proof up to what % nitro, I don't know, midwest says at 25% it deminishes, but nitrate is for shrinking, the helmsman spar urethane is oil based, hense the mineral spirts clean up. But here, I'll do you one better, a bottle of 25% 1/2A nitro(Byron) poured into the radio compartment and let to sit for 1/2 hour, will post results. It's 8:35 EST when I poured it in the compartmant, I know you all love real world testing, So here you go!
I hope you don't dissolve something with the 25% fuel.. [X(]
MJD
My Feedback: (8)
Well,it's been over and hour, I had to grill the honey mustard chicken and do the taters, it's still in the drawer, stitting there waiting for me to clean it up. The drawers under it are still dry, this box was built using wood gle, not epoxy or CA, so if it disolves the varnish, it'll eat through the glue joints too. Here's the results, but keep in mind, you need at least a week for this stuff to get a full cure, My experiment is kind of extreme, I dont expect you guys to pickle your planes in 25% nitro for an hour +.
I believe the guys at PPG told me only 2 part epoxy is nitro proof. Because I was asking what the top fuel guys paint there cars with. Or I think they said 2 part acrylic urethane is fuel resistant. I do my boats with the 2 part acrylic urethane. and running 50% nitro you better get it off quick. Or it will start to eat in. Now the burnt residue is a diferent story.
My Feedback: (8)
Well, the helmsman spar varnish works fine, I cleaned it out after sitting for an hour and fifteen minutes, no leak through or disolving of the compartment, just a little cleaner than before. I guess you could say it's fuelproof up to 25% nitro, but it's heavy for a finish, I still recommend butyrate dope, it's far lighter than minwax.
How come in the third pic it looks all messed up. There is a difference from fuel proof to fuel resistant.
Im doing a test right now but am not sure if the block of paint I have split in half is acrilic urethane or epoxy can't find the can but I do have the catylist so I will call ppg tomorrow and they will know what it is from the catylist number. I just placed 50% boat fuel on half it at 10:30
My Feedback: (8)
Reflection from the flash, here's a current photo of it cleaned out, dirt still in the corners but nothings wrong with it. I subject my field box with all my gear sitting in it and I give real world proof and some are still not convinced? O-well, you can make some of the people happy all the time but all of them never. The first photo is before dumping the 25 nitro in it, the side stains have always been there, the last 2 photos are after 1.25 hours of exposure time, the compartment is still the same, no change in wood coloration from nitro or oil in the fuel.
My Feedback: (8)
50% nitro is 100% more than any of us use, if your using 50 nitro in a 1/2A, you need prozac, too much adreline my friend. But I'd like to see the results, afraid I've never had a need for 50% nitro and assume I never will. Heck!, if I could get my motors to run on FAI fuel, I would because of the cost.
