HS-81 servo arms
NC
HS-81 servo arms
Does anyone know where I could get longer arms for a Hitec HS-81 servo(longer than what comes packaged with them)? All I can find are longer arms for hs-50 & 55s .....I need an arm about 1" in length.
thanks
-Bill
thanks
-Bill
RE: HS-81 servo arms
If all else fails, use the servo arm screw and another little bitty screw through one of the holes to attach a plywood plae to your existing arm. Then you can make an arm in any length or configuration you want. You'd probably want to use a longer servo arm screw than stock though.
Bill
I pulled an arm off a standard sized HS-322HD and it fits the HS-81. Try ServoCity for standard arms - you should find one longer than included in the package with the HS-81.
http://www.servocity.com/html/servo_arms___horns.html
andrew
andrew
