"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
MACH NONE BUILD (built up wing)
Reply
Old 11-21-2008, 03:13 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MACH NONE BUILD (built up wing)
Thanks to the Fritzke website for the plans and Freebird for the canopy, I am building a couple Mach's and this is a review of the first.
More coming soon, check back ! Matt
rc2007 is offline
Old 11-21-2008, 03:28 PM
WEDJ
WEDJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MACH NONE BUILD (built up wing)
Nice!
WEDJ is offline
Old 11-21-2008, 03:45 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pic in first post is from the fritzke website (not my plane)
Canopy and plans:
ID:	1076310   Click image for larger version
rc2007 is offline
Old 11-21-2008, 03:57 PM
Free Bird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've signed on for this one!!
FB
Free Bird is offline
Old 11-21-2008, 04:04 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This will be 4 channels, with a Cox surestart non r/c.
I am going to experiment with in flight mixture control to act as a semi throttle by pinching the fuel line with the thottle servo.
I am also going to start with the original cox plug then move to the aftermarket head and plug (Nelson).
Stay tuned !
rc2007 is offline
Old 11-21-2008, 05:26 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone have a weight on thier foam wing for this plane? (Just the wing )
I am about 11 grams without servo or covering so far.
rc2007 is offline
Old 11-21-2008, 09:20 PM
gabe200
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys where can i get a set of plans and foam wings and canopy love to build one
gabe200 is offline
Old 11-21-2008, 10:05 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cut ribs from plans then cut ribs from balsa. Wing is now pretty much framed up. Weight about 11 grams here.
ID:	1076526   Click image for larger version
ID:	1076527   Click image for larger version
ID:	1076528   Click image for larger version
rc2007 is offline
Old 11-21-2008, 10:45 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great to see a gorgeous classic being built. Don't sweat the weight of the wing, if you are using medium balsa sheet and firm [stiff] sticks, it will turn out just fine. Try to use light trailing edge stock if you can.
combatpigg is offline
Old 11-21-2008, 11:07 PM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: gabe200
Check Dave Fritzke's excellent [link=http://my.pclink.com/~dfritzke/index.html]website[/link] for a set of downloadable plans. You will have to cut your own foam wings, or get someone here to cut a set for you. The canopy is available thru Freebird - he has posted above; send him a PM.
You might shoot Steve at [link=http://www.selecthobbies.com/]Select Hobbies[/link] an email. He has had some tapered and constant chord ACE cores in stock.
Andrew is offline
Old 11-22-2008, 11:25 AM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK ladies and germs, more pics:
ID:	1076814   Click image for larger version
ID:	1076815   Click image for larger version
rc2007 is offline
Old 11-22-2008, 11:28 AM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One complete wing except for aileron linkage. Used plans to cut out bulkheads.
ID:	1076817   Click image for larger version
ID:	1076818   Click image for larger version
ID:	1076819   Click image for larger version
ID:	1076820   Click image for larger version
rc2007 is offline
Old 11-23-2008, 09:45 AM
Free Bird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey RC!
When you built the wing, did you draw a centerline on the L/E for the ribs and kept the T/E pinned to the board? TIA!
FB
Old 11-23-2008, 06:49 PM
fritzke
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey RC'07!
Looks very nice! How has the parts fit been so far?
Dave
fritzke is offline
Old 11-24-2008, 04:24 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FB ,exactly, trailing edge pinned down ribs glued to TE and bottom sheeting (everything pinned down first), the lined up the LE as careful as possible and glued freehand with fast ca.
rc2007 is offline
Old 11-24-2008, 04:28 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave so far so good, but I'm doing this one down n dirty....I am not taking the time to notch the TE and LE, just installing ribs over plans and sanding ribs to fit as needed. Your plans are perfect to get this little plane built.
By the way, I will also be installing a TD, a Norvel, and my TT .7 to find out each engines max performance.
rc2007 is offline
Old 11-24-2008, 04:32 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Building the basic fuse as shown is the most difficult part (of any kit). Make sure all the bulkheads are square, and that the fuse sides are perfectly aligned over the plans. Just tack glue everything until everything is aligned. It is very easy to make a crooked fuse (done it many times)
ID:	1078304   Click image for larger version
ID:	1078305   Click image for larger version
ID:	1078306   Click image for larger version
rc2007 is offline
Old 11-24-2008, 06:06 PM
rc2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, I am going to go with the smallest physical sized servos I can get away with...from experience on this type of plane what is the MIN torque I could get away with on ail and elevator?
rc2007 is offline
Old 11-24-2008, 08:01 PM
gittarpikk
gittarpikk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok folks, Ole lazy here has finally started the "project" I have the fuse really slicked up, and have built a balsa wing . I am making several changes My Mach None will pretty much be a one of a kind as I am doing strip Ailerons (2/3 ) and strip flaps(1/3) with mini retracts (tail dragger) I am also using a rudder. I have a Norvel .64 both early version and a later version with throttle and muffler. What I would like to kow is what experience someone might have had with this rocket on electric as compared to Norvel?
I am keeping her light as I have a lot of servos to install. 2-micros on ailerons, one mini on gear, micro on flaps a micro on rudder, and throttle and a mini on the elevator.
My intention is not a 3d as this plane is a dream pattern ship (I had one in mid 70's with CoxTD 049 and heavy 2 servos and radio)
I remember how this plane deadstick would settup 3 ft over runnway theshold and still be a foot off ground as it passed me not seeming to slow down any...so I will be doing flaps this time with throttle.
What would be best elec setup...I remember this bird would do 70+ in level flight with the Cox and a hand cut and shaped 5.25 X 4 gray prop I am looking for maybe 80-90 this time
gittarpikk is offline
Old 02-06-2009, 02:40 PM
Free Bird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rc2007, have you made any progress on your Mach None? We'd love to see it finished!
FB
Old 02-07-2009, 06:37 PM
gittarpikk
gittarpikk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Freebird...
I built the Mach None...here are a few pics... I am going to finish it in the spring...but have a few other builds going right now..
Hope this uploads
<- picture (avitar) is the only one I found on the net of a Rumplestadt... and I am currently building (2) 3/4 siz e electric versions and a full size one.. I will try to Upload a couple pics of it also I used two entirely different foam building techniques I have not seen used yet.. and may build another Mach none with one of those methods, (a bit lighter and faster to build)
ID:	1129697   Click image for larger version
ID:	1129698   Click image for larger version
ID:	1129699   Click image for larger version
ID:	1129700   Click image for larger version
ID:	1129701   Click image for larger version
ID:	1129702   Click image for larger version
ID:	1129703   Click image for larger version
Old 02-07-2009, 10:44 PM
fritzke
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice balsa carving there Gittar! And retracts no less.
Gotta love a 5 channel 1/2a plane!
Dave
fritzke is offline
Old 02-08-2009, 12:10 AM
Remby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rc2007
I would say 12oz could be a minimum on the torque. I like the Futaba 3114's as they have over 20oz, and are light and well built. You may be able to go for lighter torque, but you need to really watch the setup for binding and tight sontrol surfaces, servo stall is somthing to avoid on a great plane like these patterns.
My two cents anyway, I will be interested in hearing how it all works out.
Remby is offline
Old 08-18-2009, 09:52 AM
gittarpikk
gittarpikk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the Rumplestadt Thread... come join us in "ressurecting" this lovable old bipe..
http://www.rcuniverse.com/forum/m_89...tm.htm#8956602
