Help ID an engine
Help ID an engine
I recently aquired several control line engines from an estate. (OS PET McCoy Veco Cox Stallion)
I have one that I need help in identifying.
This engine looks like a Cox to me maybe .051? It turns over freely and has good compression, looks like it would run.
Help ID an engine
It sure looks like a TD .051. Alot of times the piston and cylinder have been moved to another engine. To tell a .051 from a .049 look for the small grove around the bottom of the piston. It's the I.D. ring.
Later,
Tim
Later,
Tim
Help ID an engine
Thanks for the info guys, it has the groove at the bottom of the piston, so it is an .051?
I will be listing these engines for sale on Ebay soon.
