Brodak Mark II engine
RE: Brodak Mark II engine
ORIGINAL: AndyW
Looks good being AAC but is that a standard plug they're using? If so, a turbo could give up to 1.5K improvement.
Unless a fella is set up to do some machining, that particular engine is not easy to convert to another plug type.
andrew
The read head ones with a carb are the MkI ones.
The MkII uses regular plugs too, and has a head that is held down by 3 screws. I'm pretty sure one can use a lathe to fit a plug/head from an ASP engine, using the stock head with 3 screws to seal the plug against the liner. Haven't done it yet but its on my to do list, I even have an extra head in case I mess it up...
There is plenty of data on the CL forums, it would need a proper plug to make desent power.
Mine did about 14500rpm on 12% nitro and a MAS 5.5x4 and exhaust throttel from litemachines (idle at 6000rpm). With a proper head and smaller prop it should do fine for sport use I think.
ORIGINAL: Andrew
Andy
andrew
ORIGINAL: AndyW
andrew
More disappointing to the RCers, no muffler and the venturi placement and angle makes it not so easy to add a throttle.
But as mentioned, it shouldn't be too hard to install a Norvel/Wasp plug. I think that Mecoa is making these now.
Then too, there are lots of burned out Norvel plugs around that with a little practice could be drilled and tapped to take a turbo. I posted a how-to a while back.
