Prop hole
MA
RE: Prop hole
You didn't say if it was an electric or not but if it is you can use one of these prop adapters.
Mounts on electric motors with a 3mm shaft and adapts them to a 5mm diameter prop shaft.
http://www3.towerhobbies.com/cgi-bin...&I=LXMSG2&P=ML
1 Post
RE: Prop hole
Graupner make prop adapters in a range of sizes for adapting various sized prop holes to various sized shafts. If you have a graupner agent in SA, ask them-if not, Hobby Lobby should have them in stock. Campbells Kits do several for the TD, but I'm not sure if they have a 5mm OD. Incidentally the Cox 049 shaft thread is 5-40 not a metric.
'ffkiwi'
'ffkiwi'
RE: Prop hole
I usuallly sleeve the prop hole down with aluminum tubing. Some times it takes a couple of short pieces of decreasing size to get down to 1/8" ID, which matches up nicely to the 5/40 Cox prop screw or stud.
