Cox reed testing
Cox reed testing
Hi there again. I have come across some material that I was told was mylar. I was given a bit of it to use as reeds, but as the weather here will not allow me to get out and try it for a good month or two, I would like to send a couple of people some to try and use as reeds, and all I ask in return is wheather or not it works. Got a couple in my engines already, but as said earlier, time and weather are a big factor for me right now. I would send out a couple of strips to a couple of individuals to try, and if it works out, I will get more to pass along. Thanks. You can post or pm me if interested.
NEW222
NEW222
RE: Cox reed testing
Hey there CP. My thoughts exactly. My parents don't look at it that way. Only 2 more months today to go till I get posession of my new house. Even have a HUGE model room in the basement, complete with slimer bench run indoors. You do have a doghouse for me on the days I bench run indoors, right? Love the madness and thinking!
My Feedback: (8)
What is this "madness" of which you speak?
I just got done testing a couple of T.D. .09's in my basement at 3 o'clock in the morning [sm=spinnyeyes.gif]
First time I ran them, I couldn't get them to richen up...even w/ the needle (s ) open 8 or 9 turns!
So...I wet sanded the front and rear surfaces of the (new, not cracked...yet...) plastic carb bodies on a mirror w/ 1000 grit...and did the same on the top of the venturi neck, then sealed w/ just a touch of flowable Silicone.
Now they will run rich @ 4 turns [8D]
MI
I've never run an airplane engine in the house. But my father-in-law and I once started a snowblower in the kitchen. It's been over 20 years and I still hear about it from time to time.
My first model airplane engine running experience was a brand new Space Bug Junior in 1953. I mounted it on the corner of a table and leg with wood screws (with my Grandfather's permission) in the living room. Since I did not have the customary door bell battery, I used my model train transformer. Little did I know that it turns on at ~13 VAC. [] . Well, of course the glow plug lit off like a flash bulb (remember those?). Sooo, I ran (literally) down to my LHS and bought a new plug, battery and clip.
Primed the engine and it started first flip. Man, it was blowing my Grandmother's lace curtains around. I had no idea it was covering them, and the wall paper with oil. When it was all over, my grandparents did not scold me, but I NEVER started another engine in the house.
George
George
NEW222, have fun in your new house. Sometimes I wish I could move up to Canada and get some land with a river and enough space for livestock and flying. Oh yah, a log cabin made out of 3 foot diameter cedars, [that way you only need to lay 3 logs per side].
George, your Grand parents undoubtedly made it to Heaven.
