Jr Falcon Almost Finished
Finally got some time to cover the fuselage for my Jr Falcon last night. Just need to cover the fin and rudder next. Monokote hinges should work fine. Need to put foam around the receiver, mount the switch and balance the model. Be ready for a maiden this week. Using a Sure Start that Tim Wiltse did his magic on before he disappeared. It has a large tank with a larger intake hole per Tim.
Mike MacLean
Mike MacLean
RE: Jr Falcon Almost Finished
On R/O? Cool! I was very surprised when I tossed my first Jr Falcon, a model that was most definitely on the high side of the weight range! Used a stock TD .049 and 6-3 MAS on a tank mount, and the thing had about twice the power to weight I envisioned, and was very spritely. And it could thermal too as I found out. Wonderful aircraft.
Mike D
Mike D
ORIGINAL: rrengineer
Have not had time to do anything to it since I posted due to my 7 day a week job. I am off the next two days for a colonoscopy, so I should find time to finish it and maybe a maiden.
Mike
Mike
I love the Jr Falcon, the whole set in fact. I have a Jr and the others waiting for me. That is a lovely model, thanks for the pics.
A bit off topic but I have had some experience of a variety of medical investigations. They didn't hurt but there was another factor involved.
I had a Barium Meal/Enema, a heavy metal used to aid an X Ray investigation. I was not aware of the relative density of Barium, it IS dense.
I went home after the investigation and voided my bowels in the EXTRA toilet, it's equipped with a pumped maceration system using 3/4" pipe.
The Barium is too heavy to be carried by the normal flush of a toilet. I had to "lower the barium by hand".
Best of luck.
WACO Brotherhood No. 14.
old git aka - - - - John L.
OR
Good to see you all building some of these fun "oldies." Back in the early 60's, I built a Jr Falcon, powered with an .049, and rudder only. It would ROG, fly well, and I could land it right in front of me. Great airplane. I went on a nostalgia trip two years ago and got plans for the Jr. Falcon from AMA Plans service. This time, I put an OS LA .15 up front, small servos for aileron, elevator, rudder, engine, small battery pack, no dihedral, and it flies like a gem. Very fast, so need to throttle back. It'll do most aerobatics, and can easily be hand launched. Some of the "old guys" (which I am also) in our club remember this model and enjoy seeing it fly. This one was a great design in the original time, and still is. Have fun with yours. Lee
Hey guys!
I almost finished my Jr Falcon and in the plans that i have the CG is not specified.
Can someone tell me where it is?
Thanks!
Thanks!
OR
My plans show the CG at exactly 2-5/8" behind the leading edge of the wing. That's a good place to start and you might move it back a little if you need to after a few flights. Good luck and please post your pictures. Lee
CA
Jr Falcon was my 1st RC powered by a cox 09. Had Halco Galloping Ghost 3 Channel radio. Still have the plane 43 years later and flew last Summer.
Good luck on your madien.
OR
I haven't weighed mine, but it has 5 (small not miniature) servos, an OS LA .15, and I tend to build a little heavy with extra plywood here and there for strength, so mine is much heavier than yours. It really depends on the engine you choose, but 500g should be no problem. If you ROG, and it doesn't want to come off, you might be a little underpowered. I can hand launch mine (a little up trim), then it almost flies out of my hand. I have to hand launch because we have a grass field. Lee
CA
I have one of these that's 43 years old. I would really like to build another one, is there anyone who cuts these kits? I've tried and don't have the talent to do one myself.
TX
Try Early RC Models - http://www.earlyrcmodels.com/ They have quite a few of the older models with laser cut parts.
SC
ORIGINAL: JWQ500RC
http://www.selecthobbies.com/kitdata...ly%20RC%20Kits
Here is mine!
First 3 flights will be electric because is kinda slower(big prop) and then I will put a OS .10 LA.
http://www.youtube.com/watch?v=GcUX-GMvhrg
Silvaire...
You have to go to the SMALL meet in Little Rock. The Hosting club has a "Condo" type birdie house for the local Martin's right at the pits. They swoop around and scoop up all the Arkansas bugs that would otherwise get up your nose and or tickle your legs whilst you are exercising your thumbs.
ORIGINAL: stunt23
Here is mine!
Here is mine!
old git - - - - aka John L.
My friend the camera man said the birds are low because the insects they hunt came down because just before raining humidity increses and they can fly no more at great altitudes!
Thats what he said he learned in flight school.
Thanks for the congrats!I`ll post another video when I`ll put the .10 in it which will not be soon.(in a month or so)
Pictures
Pictures
English is not spoken widely in Romania.Maybe 3 % of the people speak English.
I used to have a subscription to "The Times".That is an old newspaper.
