Who makes a strong .15 rear exhaust and can you get a tuned pipe for it as well?
There are several
existing old choices which you can pick up on ebay, and several available new....
Ebay Oldies
Cox/K&B Conquest- Was really timed for a mini pipe, but I have successfully run a full pipe on one.
Rossi 15- Don't believe it is available any more in this country. Very similar to the Conquest in construction/specs (I think the Conquest copied the Rossi.)
New
MVVS .15- Available from Morris and has a tuned pipe made for it. They sell one engine that you can configure as side or rear exhaust before you break it in. Strong engine (I helped a guy tune the .21 version of it last weekend. It really sang)
NovaRossi .15- CL Speed engine. High dollar, high output.
I know there are a couple I missed, but I just can't think of them now. I think all but the Rossi came in a throttled version, but most have a straight venturi version as well.
What you planning on runnin' it on?
Ebay Oldies
New
KY
Hey, thanks for the info, I'll check into the MVVS for sure. Have seen a couple cox conquest engines on ebay as well, look fast just from the picture...
I'm gonna put it in a pacer that a guy set up for an OS .15. He said it would run around 80 with that engine so a hot piped 15 should be a blast.
Bijan
Bijan
