Help w/MVVS .15
Help w/MVVS .15
I have a MVVS .15 mounted on a 32 oz, 44" span, profile w/404 sq. in wing.
The manufacturer claims 26000 rpm for this engine. I've run 7x6, 8x3, 8x4, 8x6, 9x4, and 9x5 propellers.
It's now running an APC 9x3 N spinning @ 17,000 rpm and it seems to work best.
The model flies excellent at low speeds.
Is it possible to get strong verticle performance with this combo?
It barely pulls itself out of a hover. What kind of rpm can I expect from this engine?
I run Wildcat premium 5% fuel.
Thanks for the info.
RE: Help w/MVVS .15
The 7x5 is my favorite .15 prop. My next choice next would be the 8x4.. I have never ran a .15 on low nitro.
I use 15% - 30% nitro fuels in 'em
Sounds like you have a very fun plane there.
Is'nt that MVVS suposed to be a high power .15 that rivals the older big dogs like the Conquest and the Rossi?
RE: Help w/MVVS .15
32 ozs is too much for a .15 sized 3D model to weigh.
28 ozs is more like it, not that hard to accomplish.
This will make your engine much happier. I think the best all around prop for throttle response and thrust combined is the 8x3. The 9x3 might make more thrust, but the throttle response is not as good for hover control. It also is harder on the engine.
To run the bigger props it's sometimes a good idea to lower the compression by adding a head shim. Not always a rule, but keep the idea in the back of your head if tuning gets difficult.
RE: Help w/MVVS .15
ORIGINAL: combatpigg
I'll go back to the smaller props and see what develops.
RE: Help w/MVVS .15
ORIGINAL: Zpat
Don't lose the mini-pipe unless the power loss is made up for by removal of weight - doubtful.
MJD
RE: Help w/MVVS .15
Just understand that peak power has nothing to do with what prop will work best for your airframe. Prop efficiencies are so horrible in the 6" range that a larger slower turning prop may likely be better for a draggy airplane used a as a sport flyer. The high top speeds seeen in QM15 are after having a lap and a half to accelerate to top speed so keep in mind that making lots of HP is great if you have the luxury of being able to fly straight for a football field at a time.
