Tyro and a .10?
MA
Tyro and a .10?
http://www.mountainmodels.com/images...anual-Tyro.pdf
Would a O.S .10 LA be too little power for this kit?
1 Post
RE: Tyro and a .10?
The Mountain Models website gives it as 38" span and about 12-14 oz-an LA 10 should do nicely-or even a Norvel 074. Impressive CAD work in the instructions!
The MM website has it listed at $69.00 Many years ago (ca 1974-75) I flew a David Boddington 'Tyro'-which was a Brit design, on an OS Max 10 R/C-the crossflow version-and it was quite a bit bigger than the MM Tyro design-but only rudder-throttle-so flew a bit slower than this one is likely to.
'ffkiwi'
'ffkiwi'
RE: Tyro and a .10?
No, that should power it very nicely. And whoa, talk about raising the bar for all of us when it comes to construction manual illustrations! [sm=thumbs_up.gif]
MA
RE: Tyro and a .10?
This does look like a scaled down version of the David Boddington designed Tyro Major, mentioned earlier. I have a Tyro Major that I scratch built a couple of years ago and it is quite a bit bigger than this and flies well on a 20 s stroke or a 25 4 stroke. Not very fast, but stable and durable.
The LA10 should fly yours very well. And I see it has dual aileron servos. Nice touch.
