"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
AP .061 trouble
Reply
Old 08-12-2009, 08:42 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AP .061 trouble
I recently bought this engine new to put on my hob schoolyard cub. I am using a 2 once tank. The motor would not start with by flipping it over so I had to use a 1/2a starter. even with that, it would barely start. If i can get it to start, I have to hold the tank higher than the glow plug for it stay running. it seems to leak a lot of fuel out of the front of the case. the motor also seems sloppy. I talked to a customer at the hobby shop I work at and he said that he has gp .07s and really likes them, am I better off just buying one of those?
Gto
gto0209 is offline
Old 08-12-2009, 08:48 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AP .061 trouble
See if you can find someone with a Norvel that has a bad piston/liner and swap the P/L set from the AP over to the Norvel.
combatpigg is offline
Old 08-12-2009, 08:51 PM
kpriddle
kpriddle's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From what I have read, yes, the TT .07 will serve you MUCH better! You may want to do some researching on both of these engines. I think that it will serve your curiosity well.
KP
kpriddle is offline
Old 08-12-2009, 08:59 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have read up on the ap and people have had mixed reviews. I read in one thread to replace the head gaset with a cox one. My engine did not have a head gasket. I bought a cox overhaul kit, but It did not include a gasket that fit. I thought about powering the plane witih a cleaned up cox ss, but I liked the idea of a throttle.
gto0209 is offline
Old 08-12-2009, 09:10 PM
kpriddle
kpriddle's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gto,
There is typically somethingwrong with the AP .061. Some are better than others. I will let others chime in on solutions to your specific problems. It always seems to be something, though.
Also,there areCox R/C SureStarts on the bay that you may be interested in. From the video that they advertise, they run very well, but I cannot vouch for that. Personally, if Iwanted an r/c .049, Iwould be willing to spend the money on one. That is just my opinion, though. Iknow that aNorvelcould beat itanyday.
KP
kpriddle is offline
Old 08-12-2009, 09:37 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was looking at the die cast case sure start, but I dont know if it is enough motor for the plane.
gto0209 is offline
Old 08-12-2009, 10:02 PM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: gto0209
I was looking at the die cast case sure start ......
The die cast case is not a good choice - choose the all aluminum.
Andrew is offline
Old 08-12-2009, 10:28 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will get one of the all aluminum ones from exanalook, but I think that this plane would barely fly with an .049.
gto0209 is offline
Old 08-13-2009, 02:53 AM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For what it is worth, I prefer the AP over the TT07 GP...
I don't understand your problem, sounds like there is an obstruction for the fuel, how far out do you have the needle and what fuel are you using? Have you check for a blockage in the pressureline from the exhaust?
Check the head gasket too, you can easily make a new one out of aluminium from a can.
I use a springstarter (homemaid from musicwire) on mine, the engine even has the little hole in the case for the spring. Seems they just copied Norvel completely but didn't bother to make any starter springs.
The crank to case is sloppy (too sloppy for my taste) but with 20% all castor it seem to work. The TT 07 is just as sloppy, so there is no gain there. Maybe the early Norvels , that were a bit tight, scared the manufacturers into making them way too sloppy... Or maybe they just don't care, who knows...
Mr Cox is offline
Old 08-13-2009, 11:25 AM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using hobbico 1/2a fuel, and have the needle about 2 1/2 to 3 turns out from fully shut as reccomended by the instructions. I also am having problems with the end of the muffler falling off. This engine has been somewhat frustrating compared to the other half a stuff I have. Does anyone know if this plane will even fly with a sure start? It has a 52 inch ws.
gto0209 is offline
Old 08-13-2009, 12:17 PM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The muffler is easily fixed with a bit of JB weld on one of the to parts. After curing simply sand to a snug fit and it will stay in place, this will also ensure an even pressure from the pressure feed. A quicker solution is to JB weld the things together permanently...
I've also put some JB weld on the muffler section facing the engine to get a better seal.
I've spent much less time on my AP engine then I have on the TT07, and I shouldn't even mention the CS engine...
If you have a good piston and liner in your AP there can only be a minor fix to have it going well, I would think. I would recommend full castor in the fuel, I don't know what the hobbico has in it. I'm now running 20%castor and 10%Nitro, needle setting is around two turns open and then it runs really rich. I would trust the actual turns though, if it is too lean simply undo the needle more!
When the needle falls of you'll know that you have fuel blockage... (been there myself)
What is the weight of the plane?
Mr Cox is offline
Old 08-13-2009, 12:52 PM
build light
build light's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: gto0209
Would this be the model?
http://www.houseofbalsa.com/store/st...zpEMUMpSI804f8
Robert
build light is offline
Old 08-13-2009, 01:23 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup
gto0209 is offline
Old 08-13-2009, 01:31 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would be quite a dog with .049-.061 power, but a flyable dog.
Old 08-13-2009, 01:34 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats kind of what I thought. Maybe I will try a tt .07
gto0209 is offline
Old 08-13-2009, 04:45 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think most TT07s are any more powerful than a good .049, just heavier.
That size of plane will fly just fine with a OS .10 and a 7x3 prop.....and that is a sure thing.
Old 08-13-2009, 04:58 PM
gto0209
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats kind of what I thought. On a side note, I took the motor off the plane and dissamsembled and inspected it. I found some traces of lapping/finnishing compound in it, and a few metal boogers. Ifound a cox head gasket at the hobby shop, and installed it. The cleaning and gasket worked, and the engine can now be started by flipping it, and runs reliably. I still have to set up and hing the tail feathers, before I can try the plane. I may end up just putting a .10 on it and using the .061 on a lady bug. Thanks for your help, it definitely helped get my motor up and running.
Gto
gto0209 is offline
Old 08-13-2009, 05:01 PM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Enya 09 are nice engines too...
Mr Cox is offline
Old 08-14-2009, 10:43 AM
Walther
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why is it that Enya will not bring the 06 back? I have Emailed Ken and it just seems that everyone thinks 1/2 A is dead. NOT SO!
Walther is online now
Old 08-14-2009, 11:35 AM
flyinrog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Walther
1/2 A isnt dead, its just dying,,tiny unreliable engines which are getting worse unless you go big bucks for racing,,electrics are killing not only 1/2A but the AMA as well, thats why they are begging people who fly electrics to join for $19.95 and why bother when you can fly at the school yard on saturday for nothing, no club, no AMA, no dues of anykind,,the cops wont bug you cause there will be 30 guys from south of the border playing soccer on the field...plus people as a rule change their interests over time, some quit the hobby altogether, some go to bigger scale some go to cars, or boats or heli's...my TT .07 ran and started just like an OS .10 ,not the power , but the reliability was there...Rog
flyinrog is offline
Old 08-14-2009, 12:16 PM
DeviousDave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd just got to Ebay and get one of the $40 NIB Norvels that have been selling in the last week or two.
There are plenty of brand new 1/2A's out there, anything that was ever sold is still available. Go get you some 1/2A!
DeviousDave is offline
Old 08-14-2009, 08:20 PM
flyinrog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: DeviousDave
Its definatly a buyers market,,those $100 .074 norvels are just sitting there....same with Harleys,,this is the first year I've seen big twin Harleys drop under $10k and theres a lot of them....just a few years old even,,those poor idiots that spent 30-40k for customs are praying they can get 20 for them....Rog
flyinrog is offline
