ACE Me 109
ACE Me 109
hi,
I recently got an ACE R/C me 109, I read threads about covering the wings with low temp film or even sheeting the wings with balsa, what about covering the whole model with brown paper and PVA glue and painting it with enamels? Would it mean a lot of extra weight? And if brown paper is too heavy what about using tissue and PVA glue?
What do you think about it?
Thank you
David
Thank you
David
FL
ACE Me 109
i use ultracoat on mine. light, tough, makes its own hinges. i don't sheet the wings. tried it once, defeated the purpose of building a "simple" kit! just tape like instructed and go on. don't make a BRICK out of it!
PA
ACE Me 109
I did like Wild Fred. Use a strip of 3/4 in. fiberglass strapping tape for a spar (top and bottom), then use Ultracote for the hinges and covering.
Set your iron low, and gradually work your way up. I think I was like around 240 degrees. One of the top builders in our club was fooled into thinking I had sheeted the wing first. They turn out that nice.
Robb
Robb
re me 109
thank you!
I would use ultracote, but all I can get is oracover or solartex and not in the colors I'd like for a 109.
Like you're saying these kits are supposed to be "simple", but I believe color makes half of a model.
I wonder how rooster287 finished his .
take a look! :surprised
http://www.rcuniverse.com/attachment.php?postid=478996
FL
ACE Me 109
oracover is ultracoat. it is sold under ultracoat name in u.s., but it says oracover on the backing. painting g-62 stuff is fine.if you cover 1/2a stuff in fiberglass and paint it I will fly rings around your BRICK!
me 109
well I took a look at jim ryan's models, no doubt he's a master ,but I've never used fiberglass before, I'm afraid I'll make a big mess if I use that technique now .
I will try with some foam cores I have both the oracover and the fiberglassing covering.....I'll let you know
thank you!
David
thank you!
David
