Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
G-Mark .061 R/C engine.
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 09-17-2009, 09:50 PM
Dan Vincent
Default G-Mark .061 R/C engine.
Hi Guys,
I'm getting several 1.0cc engines together to put on a famous auction site next week and decided to include my G-Mark .061.
There have been guys here who mentioned wishing they had one so I'm just giving a heads-up.
One interesting feature was a choice of beam or radial mount backplates.
ID:	1277290   Click image for larger version
ID:	1277291   Click image for larger version
Old 09-18-2009, 12:44 AM
ffkiwi
Default RE: G-Mark .061 R/C engine.
That is the scarce first 'Seagull 061" model-quite clunky and heavy compared to the later 061 in its various forms-std, R/C, heli/car and marine. I had one many years ago but traded it still NIB, as it was too heavy for my planned usage. IIRC it came in a large-ish (for the engine size) orange and blue box with a plastic slide on sleeve, all the later ones came in transparent coloured plastic boxes with a foam insert
'ffkiwi'
Old 09-19-2009, 08:29 AM
Dan Vincent
It weighs 3.2 ozs on my digital postal scale. Could be a collectible or used in a model. It's pretty close to new condition. It takes a short regular RC plug.
Old 09-21-2009, 01:03 PM
Dan Vincent
I put that G-Mark .061 up for auction today, along with seventeen other nice 1.0cc engines.
Here's the G-Mark and you should be able to find my other stuff. I should be putting new stuff up each week.
This is mainly for info for the guys who mentioned before they would be interested in some of my engines if I were to sell them.
http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
Old 09-21-2009, 01:38 PM
combatpigg
combatpigg's Avatar
Dan, thanks for sharing this part of your collection. I hope it finds a good home and hope the selling price rewards you handsomely for taking such good care of it..
Speaking of which, I had a later model .061. Had it for many years, it saw a fair amount of use. Always run with castor in the fuel. Brought it out to run after a couple years sitting in my damp and cold barn, hit it with the starter and the front of the crank broke off. It was simply rusted through and through. You could say it was rode hard and put away wet.
Old 09-21-2009, 08:28 PM
DeviousDave
ORIGINAL: combatpigg
Somewhere here in my vast library of engines, I have a G-Mark .06 CL motor. I'm sure the crank is still good... You want it? Cover postage is all I ask.
Old 09-21-2009, 10:13 PM
combatpigg
combatpigg's Avatar
DD, thanks very much.....but I gave the rest of it away some time ago.
Run with open exhaust and a larger venturi, these engines put out pretty good! [X(]
Old 09-22-2009, 09:42 AM
Dan Vincent
Thanks, CP,
I also have a MP Jets .061 RC diesel, a MP Jets .061 RC glo and a Norvel .07 RC that I might put up on ebay soon. Two are NIB and the other is like new.
I have a few hundred engines that I may sell off including three Oliver Tiger Cub .09's and a Barbini B.38 1.0cc.
ID:	1279929   Click image for larger version
ID:	1279930   Click image for larger version
ID:	1279931   Click image for larger version
Old 09-22-2009, 02:46 PM
DeviousDave
I'm glad to hear that, I have an RC motor with the car muffler on it that is a real dog. It shows promise though-It's got 1/2 hour on it and still won't hold a peak needle. It was a parts-assembled motor from Charlie's RC, and I think the screws they used for the carb are too long as they protrude into the carb spigot. I haven't touched it since maybe 1995, it might be time to give it another go.
Old 09-25-2009, 10:59 PM
ffkiwi
DD-my experience of a std 061 NIB is they take quite a bit of running in-mine hasn't been run for the past twenty years but after 30 mins bench running on a 6x3 it was still tight-and wouldn't hold a peak setting-so yours might well take quite a bit of running till its right as well. Hopefully rewarded with a long useful life.............
'ffkiwi'
Old 09-28-2009, 04:58 PM
DeviousDave
Thanks, Chris-that's good to hear. I had intended it to be used in a 'special' sport airframe and shelved it for it's lackluster running. At the time I thought it might have an air leak and was getting into the new cheap high performance Russian engines so it was forgotten quickly.
Old 10-01-2009, 01:38 PM
AndyW
ORIGINAL: DeviousDave
Dave,
I'll take that crank. I can always stuff it into something. PM me if it's still available. I have Paypal.
BTW, CP sent me the muffler so that I could rebuild mine. Still have not got around to that but maybe this fall.
Thanks CP, appreciated and not forgotten.
Old 10-01-2009, 01:40 PM
AndyW
The one I hope to re-build soon came around after I shaved the head for more compression. Worth a try.
Old 03-10-2014, 10:23 AM
SCREWLOOSETC
hi
Is dan still around?
Old 03-10-2014, 03:46 PM
Dan Vincent
Yup, Dan checks in now and then.
Old 03-10-2014, 07:21 PM
SCREWLOOSETC
Dan we did a bit of trading a while back Im in Indiana now Im the person you got the Barbini from and I got
arne Hende engines from you. I lost track of you and your old phone #is disc.now im messing with the small diesels You still have arnes Mc Coys?
Can you email me? [email protected] we could talk
Did you ever run the Barbini? Mine is still NIB You got the greenhead I kept the red head.
hope u are well
Tom
Old 03-11-2014, 02:25 AM
Dan Vincent
Hi Tom,
Good to hear from you. Sent you an email.
Yup, do have AH Mini-McCoys, Doolings, Drones, Olivers, Fox, Dyno and other stuff.
Old 03-11-2014, 11:24 AM
MJD
MJD's Avatar
'ffkiwi'
Is that because of its resemblance to a British Seagull outboard motor..?
Old 03-12-2014, 07:42 PM
ffkiwi
Nope-bore no resemblance whatsoever to the Seagull outboard. The smaller 0.5cc model was marketed as the 'Humming Bird 03' so I guess they had a bird theme going.....this is what the original G-Mark Seagull 061 looked like....
ChrisM
'ffkiwi'
Name:	G-Mark 061 Seagull RC (lhs).jpg
Old 03-13-2014, 08:23 AM
skaliwag
skaliwag's Avatar
Was the .061 used as a marine motor. A water jacket available at any time?
Old 03-13-2014, 09:56 AM
ffkiwi
I believe so-though I've never seen one in the flesh-and a car version with typical big heat sink head was definitely produced. ......
ChrisM
'ffkiwi'
Old 03-13-2014, 11:43 PM
Mr Cox
Mr Cox's Avatar
Yes, there was a car version too. It has a larger diameter head, not the higher/taller style ones that seem popular on other engines nowadays.
Old 03-14-2014, 01:32 PM
ffkiwi
QUOTE=ffkiwi;11758894]I believe so-though I've never seen one in the flesh-and a car version with typical big heat sink head was definitely produced. ......
ChrisM
'ffkiwi'[/QUOTE]
sometimes I feel like an idiot-especially after writing the quoted line above-I have one-bought on Ebay a number of years back-which I converted back to aero (which wasn't a difficult task)-anyway-I've just put it back to marine form to take these pictures...
I should comment that I've never run it as a marine unit..........I removed the cooling clamp, removed the flywheel, stud and universal and fitted a normal 3mm socket head bolt and spinner from a Brodak Mk1 049...
ChrisM
'ffkiwi'
Name:	marine G-Mark 061 (lhs).jpg
ID:	1978005   Click image for larger version
Name:	marine G-Mark 061 (rhs).jpg
ID:	1978006   Click image for larger version
Name:	marine G-Mark 061 (top).jpg
Old 03-15-2014, 06:41 PM
Dan Vincent
That engine has a Dumas cooling clamp that was designed for the Cox .049 but will fit other half-A engines.
Old 03-15-2014, 07:24 PM
ffkiwi
That's the way I bought it-it was never stated as being OEM, so I never knew for sure. Presumably the flywheel and universal are from Dumas as well.... I suppose only someone in Japan will be able to confirm if a factory produced marine variant exists.......Japanman?
ChrisM
'ffkiwi'
