"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Herr Cloud Ranger build.
Reply
Old 12-11-2009, 06:24 PM
  #51
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Herr Cloud Ranger build.
Is it a clearance problem with the right side of the fuselage? In front and in back of former #1? I would glue 1/2" triangle stock between former #1 and #2 and then get the Dremel out with a drum sander and open it up so the muffler clears.
Tom Nied is offline
Old 12-11-2009, 07:55 PM
  #52
build light
build light's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the easiest fix would be adding spacers on top of the bem mounts, say quarter inch. Otherwise I would consider a muffler extension or the above advice.
Robert
build light is offline
Old 12-12-2009, 03:36 PM
  #53
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the suggestions guys. After 5 hours of playing around today, I decided rather than add more weight Ill give up looks and hack out the cheeks. And I ran into several problems along the way. The motor mount I chose wouldn't be my next choice when using a TT.07. The beams are pretty far apart and I was commited to drill and tap 4-40 for the engine mount and that just didn't work out. I eventually drilled out the mounting holes to accept "Through Hole" 4-40s with a backing nut. (Trust me, alignment gave me fits!)
What a day! I finally figured out that I have to install the motor with the muffler screws allready installed. [:@]
I'm happy with the outcome though. Proportionately the engine looks fine, not too big, not too little and my hack job came out ok.
ID:	1332799   Click image for larger version
GaryHarris is offline
Old 12-12-2009, 05:51 PM
  #54
Invertedflyby
My Feedback: (15)
Invertedflyby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry the TT turned out to be so much trouble.  I wish I hadn't suggested it now.   But it looks like it turned out good, and it will be different than all the ones with OS .10s   It should fly the CR just fine.
Invertedflyby is offline
Old 12-12-2009, 07:35 PM
  #55
PatrickCurry
My Feedback: (20)
PatrickCurry's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dang, I feel for you Gary!  How often I while away hours on some "mini project" that frustrates the heck out of me!  Looks real nice though, it's on par with the rest of the build.   Wish I could build like that.  :-)
PatrickCurry is offline
Old 12-12-2009, 08:10 PM
  #56
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If It wasn't for the little challanges along the way, I wouldn't build airplanes! I am extreemly happy with the kit and engine so far.
After this, my next plane will be a Great Planes Tutor kitbashed for 1/2A nitro! Allready have it ordered.
Old 12-12-2009, 08:34 PM
  #57
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Something to note for those of you who are new to building kits. Never trust the plans for a true wing. Use a square.
Old 12-12-2009, 08:50 PM
  #58
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very good tip. I've built several Sig kits and have always had to redraw the wing in order to get it straight. I think something happens in the printing and the expansion and contraction of the paper the plans are printed on. Very good flying planes though.
Tom Nied is offline
Old 12-13-2009, 12:36 PM
  #59
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The left wing panel came out very straight and with only one hitch. The first shear web came up short and would not touch each rib. One of the reasons I keep scraps and actually bought a GP Pete n' Poke just to have extra lumber in case I needed it. (Lots of wood and it's cheap)
The inboard side of the wing needed a little filler and this is what I use. I live within walking distance of a Home Depot and the closest Hobby Shop is a 40 minute dive. Cheap too!
On to the right wing panel.
ID:	1333442   Click image for larger version
ID:	1333443   Click image for larger version
ID:	1333444   Click image for larger version
Old 12-13-2009, 01:16 PM
  #60
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's curious. I never had a wing where the grain of wing center sheeting ran chord wise.
Tom Nied is offline
Old 12-13-2009, 01:50 PM
  #61
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Uh oh! I think I boo-booed.
Old 12-13-2009, 02:10 PM
  #62
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think so too. Don't mean to point out mistakes. Options, 1. forget it, maybe not that much of a big deal. 2. cut it out and replace with wood running spanwise. 3. wrap center section with some kind of material like real fine fiberglass and thinned out glue/epoxy.
Tom Nied is offline
Old 12-13-2009, 02:32 PM
  #63
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Tom Nied
Thank you for pointing it out Tom. I have no idea what I was thinking.
Old 12-13-2009, 05:21 PM
  #64
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After sanding the filling down and some stress tests, I think it will be ok.
Old 12-13-2009, 06:51 PM
  #65
skyraider71
skyraider71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just found this thread, cool build!
I've considered building that one with a Norvel .061.
skyraider71 is offline
Old 12-18-2009, 03:47 AM
  #66
PatrickCurry
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Noob question:  I take it the grain is supposed to run span wise for strength?
Old 12-18-2009, 07:38 AM
  #67
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: PatrickCurry
Yes, and it follows the curve of the airfoil easier.
soarrich is offline
Old 12-20-2009, 02:00 PM
  #68
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have slacked off a little this week on the build but got a little done this weekend. I finished the right wing half and went ahead and sheeting the right side the same as the left, wrong. [:@] I dont think Ill have any strength issues though.
I joined the wing halves and ended up with 5/16" on each wing tip for my dihedral.
ID:	1338285   Click image for larger version
Old 12-20-2009, 06:16 PM
  #69
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on the wing mount. I have some sanding to do.
ID:	1338461   Click image for larger version
Old 12-20-2009, 06:29 PM
  #70
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"slacked off a little"? Hey considering the time of year and all the things we have to get done for the holidays, I'm in awe you were even able to get to the building board. I wish I could find some time to myself and even just dream at the building board. The best I've been able to accomplish is some hobby shop material purchase for a Wonder I'm trying to finish. Keep pushing forward.
Tom Nied is offline
Old 12-20-2009, 11:49 PM
  #71
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Tom Nied
''slacked off a little''? Hey considering the time of year and all the things we have to get done for the holidays, I'm in awe you were even able to get to the building board. I wish I could find some time to myself and even just dream at the building board. The best I've been able to accomplish is some hobby shop material purchase for a Wonder I'm trying to finish. Keep pushing forward.
I hear ya Tom. Besides all the holiday stuff going on, Ive been playing around with a new guitar and spent most of today researching my next build. Itll be an BUSA Eindecker 90. Not exactly 1/2a. lol
Old 12-21-2009, 12:55 PM
  #72
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, the bolt on wing mount is done and it aint pretty, or light. I may of added an ounce or so over the standard dowl rod/rubberband set up. Plus since this kit doesn't have any wing joiners, I may have added a tad more weight over the standard build.
ID:	1339051   Click image for larger version
ID:	1339052   Click image for larger version
ID:	1339053   Click image for larger version
Old 12-26-2009, 09:26 PM
  #73
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Managed to get the servos installed and cover the fuse. Yuck! Not my best covering job by far!
ID:	1342444   Click image for larger version
Old 12-19-2010, 02:33 PM
  #74
Graham MacDonald
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am courious to see how your plane flew with that dihedral measurement. I have one on the table currently and I am going to use ailerons and would like your input.
Graham
Graham MacDonald is offline
Old 11-19-2018, 10:44 AM
  #75
mwohlenhaus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Setting first shear web/dihedral brace
Currently building same model, per the wing construction directions it only has the rear innermost bottom sheeting going on prior to installing the dihedral shear web, do we just take the chance floating the brace to accommodate for the front piece of sheeting or do I partially glue the front sheeting on to fit the brace in? I am guessing you can tell I am newer to the hobby, my second build with the first being a micro telemaster.
mwohlenhaus is offline
