Which motor: Norvel Big Mig .074 or Cox .074 Queen Bee?
VA
My dad is going to buy a motor for his Norvell 1/2A Tutor. It calls for a .074 motor.
Also what is a good price for these motors?
Cox Queen Bee .074
vs
Norvel Big Mig Sport .074
I need a reply as soon as possible. Thanks in advance!
Cox Queen Bee .074
vs
RE: Which motor: Norvel Big Mig .074 or Cox .074 Queen Bee?
I don't have that plane myself but I do have both of the engines and the power to weight ratio is very different. The QB is a bit like the TT07, they both have the power of a good .049 cox but at more than twice the weight.
The Norvel .074 on the other hand has the power of an .09 engine, but at half the weight.
A NIB Norvel .074 will probably go for about $100 on the fleabay...
1 Post
Queen Bees are reasonably plentiful on Ebay and you may be able to pick one up for about $40-50. Norvel 074s are sought after and can go for over $100 on the same site. If you're prepared to wait months you may get one for a lesser price. There is a 3rd option you seem unaware of-the Thunder tiger TT-07 engine-readuily available from various retail and mail order outlets for about $50. Advantages-cheap, uses a standard glowplug, nice throttling and a good silencer. Disadvantages-not particularly powerful, and reasonably heavy.
In contrast, Queen Bees are fairly gutless, heavy for the power they deliver-but nicely made. Throttling can only be described as average-but being a reed valve they will run in either direction.
Norvel-sets the performance level for the 074 class. Light, powerful, go like stink-but they're out of production, and use an insert type glowhead which is expensive and not normally stocked by local model shops [and is out of production!] However MECOA are producing aftermarket Norvel head inserts for 061 and 074 and I believe Merlin are as well-though I'm not 100% on that-Merlin ARE doing inserts for the 049/061 size, I'm not sure whether they have tooled up for the larger size.
recommendation: if you have the money, go with the Norvel, and learn to live with the head insert issues
if you're in a hurry-go with the Thunder Tiger
if you're curious-get a Queen Bee [my personal opinion is there is nothing to recommend them over a TT07.....and I own both]
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
1 Post
No point in seeing someone waste money unnecessarily! Old story-you can do it cheap-or you can do it well-but you can rarely do it cheap and well.
ChrisM
'ffkiwi' [about to depart for NZ Nationals- to do-what else but FF of course?]
ChrisM
The tutor is a 4 foot wingspan 3 channel /trainer/floater plane..an .049 will fly it,,but much like the current few cloud ranger builds going on, it could probably handle an OS.10..nice, more available,,runs like a timex.....I have an .061 sig rascal,,that I am changing to a float plane so I took out the .061 (boring) and put in the .10, havent had a chance/made the time to fly it just yet,once I test out the .10 then I will add floats, its for a friend with a good sized pond...Rog
I would suggest an Enya 09 r/c or an OS 10 r/c. They both swing larger props than the norvel or queen bee. They are a little heavier but have much nicer idles and transitions to full power. At the speeds the Tutor flies at they would be a good choice.
I have an AP Wasp .061 in a half size Kadet and like it a lot although most people i've talked to have had bad luck with them. Mine is two years old and still running strong.
If you have time to look you might find an older 06 enya r/c on ebay or similar. They are equal in power to the QB and built like a swiss watch. I have one but it is a diesel and probably something you wouldn't want to fool with. I've seen new glow 06 enyas for sale as recently as last year at Richmondrc.com.
I've pasted a couple of ebay links to typical engines as well as a posting from this forum detailing enya prices.
http://cgi.ebay.com/ENYA-09-RC-ENGIN...item45f01b2337
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
http://www.rcuniverse.com/forum/m_7085790/tm.htm
J
J
The QueenBee is the only engine I ever bought, [new or used] that I could never get to run. Sent it back to Cox twice fuming mad and they never "made it right", they didn't do anything more than return it back. At the time the price of this failure was a huge hit for me to take financially and I never bought another new engine from them again. I also passed the word on to everyone within spitting distance, but by this time Norvel had already taken over.
So, to put it nicely, the topic of this thread [AFAIC] is ....
FTQ!!!.... buy the Norvel!!
ORIGINAL: combatpigg
The QueenBee is the only engine I ever bought, [new or used] that I could never get to run. Sent it back to Cox twice fuming mad and they never ''made it right'', they didn't do anything more than return it back. At the time the price of this failure was a huge hit for me to take financially and I never bought another new engine from them again. I also passed the word on to everyone within spitting distance, but by this time Norvel had already taken over.
ORIGINAL: jtnktz
Cox Queen Bee .074
vs
Cox Queen Bee .074
vs
As mentioned, the TT .07 is a well made motor and is in surrent production. Not a killer powerwise, but it does a lot of things well, and the pwoer comparison to other small motors is about all negative anyone has to say, other than that it behaves nicely and would power that airplane well. It would be a logical choice as far as 1/2A-ish size engines, or you could you up the motor choice to an OS .10 or equiv.
MJD
