Fuel Mixing Guide
Fuel Mixing Guide
I have seen a lot of mention of adding more oil or nitro content to fuel on the forum lately. In addition to that, I am planning to mix a high nitro fuel mix for my next speed runs with the Caliente, and, I have been playing with the oil content on running .010's.
With all of this fuel mixing, I wanted a quicker way to figure up the percentages I was achieving by adding whatever component to my existing fuel.
I came up with the following spreadsheets to help me do it. They are 'plug n chug' spreadsheets which allow you to enter your current volumes, and then your proposed amount of fuel component to add.
I figured others might have a use for this thing too.
Ya'll try it out (and if someone wants to check my math, please do so....)
Fuel Mixing Guide
Hey Jeremy,
If you need nitro, let me know. I order it by the 5 gal drum. Mixing your own is very benificial and economical. Randy (Digger) and I were using some of my Lou's Brew at the Smalls. As you could see, his Panther ran pretty well on it. We were using a 25% nitro, 20% lube mixture. All castor.
Oh, by the way. If you want one of the Noblers I have order, let me know. They should be here early next week. Are you still coming to our C/L fun-fly?
Louis
"[email protected]"
Louis
"[email protected]"
Fuel Mixing Guide
Hey Jeremy,
Louis
"[email protected]"
Louis
"[email protected]"
Fuel Mixing Guide
That is awesome Jeremy.
and the excel format brings me back to my Electrical Engineering days.
So where would someone like me obtain Castor and Nitro. I know that Sig sells castor but my LHS doesn't stock it. FOr some reason I thought that castor was a pretty common thing. I have looked in hardware stores, grocery stores, autoparts stores and can't find it anywhere.
Do you guys just use Sig Castor?
What about Nitro? That seems a little more dangerous and a little harder to find. Where do you get 5g drums of it?
What kind of prices would I expect to see on these?
Thanks!
timothy
Thanks!
timothy
Fuel Mixing Guide
Nitro: VP Racing, check the internet for the nearest one to your geographic area. A 5 gal drum will cost $190.00 shipped to your door. For homeland security reasons you have to fax them your picture ID.
Methanol: Check with your local speed shop. Will cost anywhere from 2.00 - 4.00 a gallon.
Lube: Yes, Sig castor is probably the best. Most use a combo of Klotz and castor. Your local hobby shop should be able to order Castor and Klotz by the gallon from Sig. Castor will be 19.00 - 24.00 a gallon and the Klotz will be 24.00 - 28.00 a gallon.
