Is this a stock Cox part?
My Feedback: (98)
I bought this on ebay, is it really a Cox part. I has a hole across from the stem that looks like a set screw would go there, but it's not taped, should it be?
I'm thinking of using this as the basis for an exhaust throttle, anyone done that?
RE: Is this a stock Cox part?
Yeah its stock ,you dont see them very often its not a throttle ring, its an exhaust collector, hopefully to aim the goo away from the plane,,I dont think I ever flew a plane with one on it....but yours is only like the 4th one I've seen...Rog
ORIGINAL: flyinrog
Robert
ORIGINAL: soarrich
I does give you a variable speed, but it will not be the same as a carb on a regular intake engine. It is quite amazing though how the engine just keeps running although it seems like the exhaust is completely blocked.
Keep the primer hole for easy starting (unless your putting it on a sure-start with the choke backplate).
ON, CANADA
This was most often seen on the Cox cars.
AndyW posted something some time ago on one of his experiments on throttling.
They are not that effective a muffler but they will take a bit of the bite out of the exhaust note of your Cox engine without reducing the RPM too much and they do help in keeping some of the goop off your plane.
I have about 4 of them myself that I got from Dan Sitter on eBay (Coxmania).
cheers, Graham in Ottawa Canada
And I just ordered three. Goop directors, and fun to have in the 1/2A tidbits drawer.
Hmm, could you get a little tank pressure from these I wonder.. [sm=confused.gif]
MJD
MJD
ORIGINAL: MJD
MJD
MJD
My Feedback: (8)
My yellow van's ( I think it was called "Action Van" or something hokey like that? ) engine had one of these collectors on it...and IIRC my Adam-12 police car did too. I got rid of 'em because they cut down on the power. Never thought of using one on an airplane's engine?
ORIGINAL: flyinrog
I dont know how you would go about separating the goo from the ''pressure'' on a tanked or product engine tank, the trumphet method works pretty well...I have one on an engine Tim Wiltse made for me, that was the first one I'd ever seen, only a very few since then...Rog
MJD
