Found an SSR 1/2A
NJ
Found an SSR 1/2A
I recently discovered an SST I put together 26 years ago never flown. I have to recover the fuse and clean some of the fuel. I am thinking of a TT .074. Does anyone know where the CG is on this plane don't have the manual. Thanks for any suggestions.
RE: Found an SSR 1/2A
Here is a pic of the plans - there is quite a range for the CG. You should be able to get a pretty good idea by figuring the CG as a percentage of chord and applying to your fullsize wing.
Based on a 7" chord, the CG falls between 1 7/8" to 2 3/4" from the LE.
andrew
andrew
