"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Home made Cox Texaco
Reply
Old 04-30-2010, 09:16 PM
jsesere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Home made Cox Texaco
I am building a not for competition Texaco .049 engine from spare parts. I have everything need except a piston/cylinder. I don't want to buy a new one and I was wondering if I could substitute a #4 piston/cylinder from a Tee Dee .049? I'm guessing it would work and have a little more power. Any pros and cons anyone can think of?
jsesere is offline
Old 04-30-2010, 09:54 PM
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Home made Cox Texaco
To duplicate the Texaco .049, I believe you need a #0 cylinder with no SPI. It will also help if you use a tank with a Golden Bee intake. The smaller intake tube is required. A BW sized intake will not give the required results.
controlliner is offline
Old 04-30-2010, 10:46 PM
jsesere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Texaco tank, glow head and will be using a Widow or Bee body/crank. This is going on a Cox Thermal Hawk just for fun. I just need the engine to get the plane to altitude.
jsesere is offline
Old 04-30-2010, 10:47 PM
SGC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can find a No 0 piston/cylinder set here :- &bay No 150385083763
Stewart
SGC is online now
Old 04-30-2010, 10:51 PM
SGC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jsesere,
To get reliable runs on the larger props the texaco had a small dia intake venturie, if you have some older cast tank backplates from baby bees or golden bees , check the intake sizes and use the smallest.
Stewart
SGC is online now
Old 04-30-2010, 10:55 PM
jsesere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Texaco back plate.
jsesere is offline
Old 04-30-2010, 11:55 PM
build light
build light's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jsesere
What jsesere is trying to do is simply take a complete Texaco engine that needs a cylinder and pistyon and without trying to duplicate the qualities of the Texaco engine, to simply put together an engine that will haul his Cox Thermal Hawk into the sky to have fun flying.
My answer is to save the Tee Dee assembly for a Tee Dee and just use a common Sure Start assembly.
Robert
build light is offline
Old 05-01-2010, 08:23 AM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok group check out Cox international in Canada 1 877 769 1779, they have a web site too, just about everythig you can think of for cox I just bought a new sure start 049 for $14.85
spare head gaskets and some spinners a new baby bee 39.95 to 49.95 a new cylinder piston and rod assembly 049 $4.95, they have crankcases, shafts think $4.95 also
plus about every part out there for a rebuild martin
AMB is offline
Old 05-01-2010, 08:45 AM
gcb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AMB
I peruse their site occasionally just to see what's new. A few months ago I noticed they have prop nuts for the Space Bug, SB Jr, and Thermal Hopper...so I ordered some. Of course you can't get off that site without a few "extras".
http://coxengines.ca/
George
gcb is offline
Old 05-01-2010, 01:12 PM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ditto on the suggestion to use a Sure Start cylinder and piston. You can also use a regular glow head instead of the Texaco head if you shim it to a lower compression ratio by using 3 or 4 head gaskets stacked up. You'll also find that it runs better when used with a big prop on no more than 10% nitro fuel. And 5% is even better. The big prop lugs it down so much that it'll run far too hot with the higher nitro. For a prop go with an 8x4. Expect the engine run to last a good 3.5 to 4 minutes with this setup. If that is too much then substitute the bigger tank bell for a Baby Bee tank bell to cut the run to 2.5 to 3 minutes. You'll find that the needle valve is slow to respond so make small adjustments and wait a few seconds to see the effect. And finally at these revs you MUST seal the needle valve against air coming in along the threads of the needle valve. I did this by replacing the tension spring with a thin filed out washer over the needle theads and a carefully cut length of silicone fuel tubing to replace the spring. The washer keeps the tubing from climbing over the top ridge. Cut it to length and with accurately square ends so that the tubing provides good friction over the range from closed to about 6 turns out.
With fine tuning and prop selection the "pros" are still getting close to 4 minutes for Texaco competitions. But for just sport flying you can easily reduce the power to produce a gentle climb and get the times I've posted without any significant complexity.
BMatthews is offline
Reply
Display Modes
