Maybe if I post this I'll be shamed into finishing it..
Another one of my famous last-10%-to-go projects needing the final push, the Fruipita (named after a bag of candies I ate while building it). What you see here is less radio and pushrods, but with aileron torque rods - yes Ma one servo, they're plenty stiff and that wing is thin - and weighs 197 grams/6.9 ounces. So add two HS65HB's, a 300mAh NiMH (33 grams) plus an Rx (dunno what yet gotta buy one) and pressure bladder and I hope I can keep it
RE: Maybe if I post this I'll be shamed into finishing it..
ORIGINAL: MJD
andrew
What size prop will you use with that engine? Is there anything special you have to use as far as fuel tank? I know mufflers cut power but are mufflers available?
Vroom Vroom lol Is this something that could be flown around the yard with light wind? Will it have landing gear?
My Feedback: (10)
Why ask Drube, It'll never run much less actually fly. There is only an hours worth of work left. He's moved on to a new nearly incomplete project already...heck he has already started a similar thread on a totally different model that has 90% of the CAD done.[X(]
ORIGINAL: vicman
I asked for it!
Soon as I get down to the LHS I'll get me some servos and another Rx and off we go.
Props suitable for this thing would be APC 4.2x4, 4.5x3.5, or composite 1/2A speed props like 4.25x4/4.5/5, that sort of thing. You could fly it on 1/2A combat props but those would hamper top speed although the pull would be tremendous by comparison. It's supposed to make peak power at 36k, and not to be propped for less than 30. Muffler? Nope, not a chance, bring hearing protection. Fuel - typical 1/2a fare is fine. Tank is a pressure bladder.
MJD
QC, CANADA
Hey! make sure you have her dialed in! I will be visiting you this summer you know, If I ever get that bladder tank from you so I can get my Q125 racer back in the air. I just re-built it and its now got a Picco on the nose waiting for a tank!
WOW FSR! Lookin' pretty hot! [X(]
MJD, hfenn summed it up pretty good, the last 10% does seem to take 90% of the time.
Tighten up the old moolabunda and get your's done, tested, perfected and put away for the big day down at Vic's Speed Rally.
I'm curious to see how the CG on your's works out. It looks like it ought to haul!
ORIGINAL: forsakenrider
MJD
ORIGINAL: combatpigg
I intend to have this all ready for NC. With luck I won't be test flying the .65 Demon down there..
MJD
ORIGINAL: AllTheGoodNamesAreTaken
Is that a......clown wig?????
I just try to concentrate on the airfoil (slick, BTW) and ignore the rest.
VA
MJD,
Dont make me put you on the wall of shame of unfinished planes. Looks like that plane would fly awesomely!!! Finish the project get her flying!!!
It'smerely the dining room table, with the usual junk that has to be cleaned off every meal - clown wig, my son's diabetic kit, overdue bills, torn envelopes, the Alien VHS set my son bought at a garage sale, etc.
I assure you there is no kinky stuff going on involving my wife dressed as a Roman gladiator and me in a clown wig, stockings and high heels, body lotion, and stray animals.. none whatsoever.. [sm=angel_smile.gif]
MJD
MJD
ORIGINAL: MJD
MJD
MJD
ORIGINAL: hfenn
The last 10% takes 90% of the time.
That should be framed and hung above everybody's workbench.
