Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Need help with Simple Extra .10
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 06-14-2010, 12:28 AM
Nitro66612
Default Need help with Simple Extra .10
What I need help with is finding out the brand and the C.G. for this plane. The plane is full working surfaces, has a O.S LA .10, wingspan of 35.25", and a length of about 26.5"
Old 06-14-2010, 12:40 AM
Nitro66612
Default RE: Need help with Simple Extra .10
Well I found out that the brand is Ace R/c but I still need to no the C.G.
Old 06-14-2010, 02:42 AM
Mr Cox
Mr Cox's Avatar
Start at the spar and tune from there...
Old 06-15-2010, 12:57 PM
Nitro66612
Last time I did that I crashed a plane so I would kinda like the measurement so that it has a better chance
Old 06-15-2010, 01:40 PM
Mr Cox
Mr Cox's Avatar
Was that crash due to wrong CG?
The only dangerous part is to have it too far towards the rear, so start a little forward of the spar then...
I've never had a plane with a regular wing that wouldn't fly with the CG just forward of the spar, i.e. when balanced on the spar with empty tank the nose should point slightly downwards.
Old 06-15-2010, 01:50 PM
flyinrog
Thats kind of under square compared to the Herr extra mine is 35 long 36 wing... and its right on the spar with an OS .15
I'd start maybe 1/2 and inch in front of the spar, hopefully you can just move the battery forward...nose heavy is always better than tail heavy.....Rog
Old 06-15-2010, 02:17 PM
Nitro66612
Oops should of fix the dimensions for you: wingspan is 35" and length is 27". Ill try right in front of the spar and see what happens
Old 06-15-2010, 02:21 PM
Nitro66612
ORIGINAL: Mr Cox
I dont think it was due to I did balance it on the spar with it being a little nose heavy. It just kept stalling the picking it self up just to stall agian. when I went to land it, it snap right over and stright into the ground just to make toothpicks
Old 06-15-2010, 03:07 PM
combatpigg
combatpigg's Avatar
Go to Geistware and plug your numbers into their CG calculator. 25% MAC is considered slightly nose heavy, but a safe starting point.
If the wing has an equal amount of taper...front and back, then just treat it like a rectangular wing and set the CG 25% back at the wing root.
