COX 049 Bee mixed parts.
RE: COX 049 Bee mixed parts.
Another Skyline .049. Took this pic in '07 when I received it from Tim. It's been flying strong for over 2 years of hard use on my Skydrill. Lots of attention to piston/rod slack and frequent resets have kept it going almost as good as new. Have experimented with several props and am currently running the black rubber ducky Cox 5x3.
ORIGINAL: Tee Bee
Does this count? It's a Skyline FX .049 from Tim Wiltse made from a stock Surestart. He modded the cylinder, piston, rod, and backplate. He made the spinner, turbo plug head, and prop driver. I haven't run this one yet.
Here's a better shot of an engine with one of his
crankcase assemblies with his high performance crankshaft and spinner.
Here's a Mangusta DR .049. I bought this one from Tim in '08. I can't believe I still haven't gotten around to running it. To me, this thing is a work of art. Rear induction with lots of mods and custom made parts. Another member of this forum has sent me a set of plans and parts for a future 1/2A speedster kit and this engine is destined for the firewall if it runs well. There will be a build thread of it when the time comes.
ORIGINAL: Tee Bee
Whew, I need a cigarette.
Did someone say mixed parts? I've been running this one on my Das Splat Jr lately. It has a TD .051 bottom end breathing thru a custom Dickeybird reduced-size venturi. The top end is a SPI piston/cylinder combo from Vintage Glow Engines made from Surestart parts. It has a Valentine turbo glow plug head. Also note the custom engine mount I found in a box of Cox parts I purchased at a swap meet several years ago. Runs great on a standard vented tank setup without a pressure tap. This combo ran great at the SMALL Fly-In a couple of weeks ago until a cracked fuel line in the tank followed by poor piloting on my part resulted in a hard landing causing some minor damage and fuel-soaking inside the plane. I'm almost done with the repairs.
#32
http://halfa-works.com/index.html
That's Tim Wiltse's site.
Scroll to the bottom of the parts page.
You might want to contact him(phone) first.
#35
SC
Nothing too exotic, but a Golden Bee tank and backplate, Sure Start front and top ends, Galbreath head and Nelson plug. Currently resides in my Skydrill and most recently flown at the 2010 Little Rock SMALL.
#37
SC
ORIGINAL: dckrsn
hfenn,
Exotic-exshmotic. Nice engine!
How many head shims do you
typically use? Do you go for
speed or duration?
Tnx.
hfenn,
speed or duration?
Tnx.
#40
LA
Question about the Kustom Kraftmanship backplates. What’s under the jam nut, a split cone or an O-ring, or? Never had one. Wasn’t there also a KirnKraft?
Thanks, Al
Thanks, Al
#42
Yuu, read the post.
I'm not sure who made it but it's working well so far. I'd never be able to bend one up that nicely. Was just one of several little treasures I found in a cigar box of Cox-related junk I picked up at a swap meet at a Big Bird fly-in of all places!
#43
ORIGINAL: Big Al-RCU
Thanks, Al
Thanks, Al
The KK valve assy. features a split collet under the nut.
Tough for me to photograph, but here it is. Click on the photo.
I've heard of KirnKraft, but know nothing about them.
Bob
#44
NY
dckrsn : Thanks for all your engine pictures and information. I wish other readers would contribute.
I am using my computer scanner to take my pictures, it’s a lot easier than using a camera.
#45
ORIGINAL: t587y28
Looking forward to seeing yours.
Sorry for hi-jacking your thread.
Bob
#46
LA
ORIGINAL: dckrsn
Al,
Bob
Thanks, Al
Thanks, Al
Bob
Al
#49
ORIGINAL: fizzwater2
Wasn't Kirn Kraft the forerunner of kustom Krafstmanship? Dale Kirn, I believe it was.
Dunno.
Dale and his daughter Mary Kay were a record setting 1/2a speed team in 1980.
This was probably Joe Klause's heyday for cox engine rework,mods,etc.
There must be some info out there.
I gleaned this here. http://www.modelaircraft.org/mag/200.../onthefly2.htm
Kustom Kraftmanship/KirnKraft hmmmm. Who knows?
Bob
