Please define some Cox terms
I've been checking out the Cox International website and terms such as Tee Dee (TD), Medallion, and Sure-Start are used regularly with no explanation (that I could find anyway) of what they mean. Can somebody explain how a Tee Dee engine differs from a Medallion engine and where the current production "Bee" engines fit in? Also, I've noticed that "Sure-Start" engines don't have the coil spring behind the prop. Therefore, what does Sure-Start refer to?
Many thanks, Harvey |
Those are the classic terms associated with Cox engines. I bet you will find answers to most or all of your Cox questions here:
http://www.mh-aerotools.de/airfoils/cox_frameset.htm Sure Start refers to engines with the newer plastic backplate that has the choke tube. Medallions - sport front rotary intake TD - competition/higher performance front rotary intake |
Thanks MJD!
