Cox Reed Valve
I needed a reed for my black widow so I just bought the cox overhaul kit #1300 and It had a metal reed included(not copper brass or mylar, SILVER COLORED METAL!!). It ls a circle w/ both sides cut off almost like an oval shape. will this reed work w/ the "G" spring on the widow?? This must be the problem or else Im hallucinating I have tried everything and this is my last option!! I have been trying to get this thing runnin for weeks! I just wanna be a good cox owner!!
Cox Reed Valve
well I put it in regardless. It sealed when i sucked throught the venturi valve and it released when i blew through it. Tommorow this thing better start!!
Cox Reed Valve
no reason why it shouldnt work, but i think the mylar and silver reeds like you have are sold with the newer plastic cage reed retainer. But if it works, it works!
If not I can set you up with a copper reed and retainer... AJC |
Cox Reed Valve
The last time I talked to Cox, they said they were supplying stainless steel reeds. supposed to be better than mylar, and work as well as the copper, but no corrosion from fuel.
See Cox black widows are Sexy!!!!
Not one of you Norvelites' BigMigs wear a G-Spring........ :eek:
Seriously..... I pulled open a backplate motor I picked up at a swap meet, and found the same little silver reed. It was a surprise...... I had not seen one of those before. I have always had the copper, or the white or clear mylar reed. |
Cox Reed Valve
was it a cox? did it run w/ the silver one??
Cox Reed Valve
EURIKA It works!! Finally after the overhaul and new reed, I got the thing started !!
Cox Reed Valve
CONGRADULATIONS!!!! CASEY!!!!! :D
it feels good huh...? |
Cox Reed Valve
Yes, Yes it does. and you helped by tellin me 3 1/2 turns !!! just started it again!!! runs great!!
