RE: Digital Servo Setup
What "will not travel as far as the other"? The elevator halves, or the servo arms themselves? Perhaps your friend didn`t mean "meter", but rather the HT-Programmer which is used to set servo center and end points (digital only). Jetech05 is right. If the linkage is correct/equal on BOTH elevator halves, there should be no need for a servo meter/programmer. Unless the previous owner (if any) programmed the servos and did not reset them/it to factory specs? Gezzz.....I hope that made sense! LOLOLOL
