RE: Engine For Kwik FLi Mk. III
Thanks for the info Chris! That sounds like a similar product that is used to clean aluminum truck beds and trailers. Also mixed with water. I've seen it applied with a pressure washer. It leaves the aluminum clean and very bright! I think it's sulfuric acid. That's what I was hoping the wheel cleaner would do. Maybe I'll try soaking it a little longer in the wheel cleaner.
