Where do I mount the charging plug?
Frogive the dumb question, but what do I do with the receiver battery charging plug? My first thought was to leave it laying inside the radio compartment. After all I'm probably going to charge it at home, with the wing removed and the compartment exposed.
But then I wouldn't be able to check the battery voltage between flights. Are these things typically mounted so you can access them from the outside? I've seen one (and only one) commercial mounting gadget for this purpose. Is that what everyone else does? Or is there some way to mount it myself with some glue and balsa?
I'm so new to this I just haven't seen how other people do this.
Thanks so much.
