RE: 162
Hey Winglift, Here is what I used to attach the templet to the wood. Just give it a light pass and it sticks pretty good. Seperation is easy and the adhesive isn't noticable on the wood afterwards. You can stack as many sheets as you need. I had to make two of each rib.
Also, 3M makes #77 spray and I found some really cheap stuff the other day for $4 a can but haven't tried it yet. I believe the NAPA spray was $10.
Hope this helps,
Kelly
