RE: Align Fuselage 600N
Basically, its the mechanical guts of the pod and boom that will be installed inside the scale fuselage. The hardwood blocks that I referred to in the previous post would go between the floor plate in the scale fuselage and the landing gear attachment on the mechanics. It didn't need much, perhaps 1/2" or so. You will see this when you trail fit the mechanics in the scale fuselage for the first time. Then just measure the height you need (its not exact) and make a couple blocks to give you the height you desire.
