RE: Electric Rotowing
The drill type is probably what I need? it may fit different sizes although he quoted 2.6 as a diameter at it's largest or smallest dim.? I'll have to talk to him sounds like the set screw type may fit one size only.Shaft has no flat machined on it completly round.They look nice counter rotating set up three blade props.I've heard the motor will turn in reverse.Don't know but it seems one direction will produce more lift than the other?Got a Headache yet? I should enter that lifting contest? I have to balance the wing in all directions so I have to know if the adapters extend the shaft affecting were motor sits.Don't worry I'll stand behind my car.I don't expect much of a crowd Thanks alot p.s.I'll probably mount power supplies for each motor in pods uder the wing eliminating contacts or using them for something else?
