RE: Servo Burnout
On a regulator where you're giving a constant voltage through the entire use, you'll get longer life out of the servos at 6.0V. 6.5V continuous is right at the top of the range of the servo.
If you need more torque for a specifial application that the servo on 6.0V will not provide, I highly recommend the 94780.
Mike
