RE: Newbie to Gas General Information
40. After months of never having to address "oil ratio", it is time to do it here. The OIL you choose is not as important as the mixing ratio you use. You are GUARANTEEDfailure **if** you use crappy oil AND too lean a ratio. Or you will GUARANTEEfailure using the FINESToil you can find or buy ANDtoo lean a ratio. Oil lubricates the innards, keeps parts moving like they are supposed to, and helps dissipate heat. So here is "Bob's Newbie Gas Advice for OIL" 1. Contact the engine manufacturer to find out the ratio they recommend, AND read the manual. 2. Select an oil that is available in your area, not too exotic, and something you would trust your most expensive chain saw or weed eater to. 3. Mix the oil properly, and 4. Do NOTAdjust the engine too lean.EVER.
