EQ6 Ign Question
I am using an Airtronics 10 channel reciever with the EQ6 and am using channels 2 thru 7 of the EQ6 for control surfaces. Both of the battery power plugs are used in channels 9 an 10of the reciever. I am confused on where to assign the igniton cut off to. Can I move one of the control surfaces to channel 1 or 8 on the EQ6 which means plugging one of the power plugs into an aux channel. I thought I read not to do that in the instructions. I don't want to burn anything out. Is it possible to assign one of the control surfaces to channel 1 or 8 of the EQ6. Thanks in advance
