Here is a link to the 7C 2.4 manual:
http://manuals.hobbico.com/fut/7c-2_4ghz-manual.pdf
As I remember, it is not obvious which channels are selected as the second Elevator half other than the fact that the second Elevator servo is plugged into Ch 5, Ch 6, or Ch 7. If you are using Flapperon, as well, then Ch 6 is usually the choice for the 2nd Aileron.
There are switches assigned to some channels and they need to be set to Null if you are using that channel in a mix.
Since Ailevator allows you to link the Elevator halves to the Aileron stick, you need to set the Aileron component, of Ailevator, to Zero, or you will get some interaction.
I have used Ailevator in both the 8AUPS and the 9C and I have not found anyone that uses the Aileron component. I tried it, but I did not find it useful.
You might place a call to Hobby Services and ask them for the specifics on the Ailevator program in the 7C 2.4, as the manual is somewhat vague.
