RE: Power15 cutting out
It may actualy be too much prop for the motor.But it's the battery that is being "Dragged down" by the amp draw and causing the ESC to cut out.That prop, on that motor is toomuch for the battery.With a better battery,it might then be too much prop for the motor. You really can't get too many watts from a motor,unless You have a battery that can push the watts through it
