RE: midwest sukoi to electric
It doesn't matter which motor lead plugs into which ESC lead. If after you have assembled the power system in your plane and you're ready to check it out, if the motor runs in the wrong direction when you advance the throttle, switch any two leads and the motor will reverse direction.
