RE: 1929 Travel Air
Thank you, do the bolts go all the way to the firewall of is there a nut inside the caps. My guess would be bolt all the way through so nothing comes apart. I saw in the pictures how Greg mounted the batteries and esc. I guess that means you have to pull the cowl after every flight, probably better that dropping the wing with all the flying wires.
Harry
