RE: New Krill Spark Evo I- Build Thread.....
I've often wondered if servos marketed for R/C cars would be useable in aircraft. Since the discussion came up in this thread, I thought I'd contact Futaba and see what their position would be on the subject. For what it's worth, this is what I received:
"Car servos were designed for ground applications and as such the gearing is not as precise as aircraft servos. If you were to use those you could experience flutter or failure. If you decide to use them in such an application , you do so at your own risk."
Mike
