RE: SD-10G Service Bulletin
The gyro is plugged into#5.
the guess I'm missing a step in setting up.
I reduced the EPA as my controls had started to bottom out. I reduced elevator,ailerons and Pitch so one servo wouldn't over take the other. What should be a safe travel setting as I'm not a 3-D yet. I'm limited. I was thing about -2 degrees and+9 for pitch. Your thoughts will be helpful.
