RE: Rcexl Opto Gas Engine Kill Switch v1.2
A volt meter would suffice as a substitute for the engine, if there's > 4 volts in the output of the Opto-Kill switch the engine would still be running. If this is happening you should set your failsafe for that channel to shut off the ignition in the event of a signal loss.
