RE: R/C motor for C/L ?
They should run fine for just putting around the circle. Having a good venturi will benefit only if you want to do the AMA stunt pattern. I've used a Fox .45 R/C with no problem on a Sterling bearcat. Just remember to keep the tank centerline in line with the carb on a profile plane and all should be fine.
