I use a long piece of the blue nyrod ( inside usually yellow & outside blue ) and I use silicon to adhear it to the inside of the fuse and put the wire in it. If possible make an opening at the rear and slide a part of the tube outside (1/16 - 1/8" ) and then you can have the antenna sticking out the back.
Doug
