Hey guys,
Nick,
Have you done your piston rings yet? Hope they go on OK, it can be tricky on those small rings. I actually have a piston ring installer at work for larger automotive style piston rings. It's quite a strange looking contraption, but it actually does work, helps prevent broken rings.
The new power supply and bench multimeter sounds cool...what outputs does the P/S have?
JPEE,
Sorry your internet/cable went out as well...and glad to hear is was a short term outage. Mine would have been a bit shorter had I realized I was the only one that was still out...
I got ya beat by a little bit on the speedtest.net score, but yours is no slouch either...
I actually pay extra for a service called "blast" for my internet...
Glad you got out and got some flying in...and knocked some of the "rust" off...
Mark,
I built one of those "Visible V-8" engine models when I was a kid...it never did work quite right, I've had a lot better luck with real ones...
You are a brave man to replace the head gasket on an Isuzu...I remember the old Isuzu Impulse...the turbo ones always used to crap the head gaskets...OMG, what a PITA those were!
Hope you guys in the warmer climates get a chance to fly some...
Glenn
